Tachometer light is out
The left side of my tachometer light, from about 1k-3k, is burnt out. Obviously I'm going to take apart the dash and change the bulbs, but I just wanted to go ahead and change them to LED's along with the clock and climate lights.
Where can I go to find out which LED bulbs I need and also is there a write-up on here of how to get behind the instrument cluster?
I saw the DIY on the clock light, so I know how to remove that part of the dash, but when it comes to getting to the bulbs behind the cluster, I'm lost. I just want a little heads up before I spend all afternoon tearing it apart.
Unregistered Member
Well once you take off that part of the dash, the cluster will just be sitting there. Four screws are holding it in, so just take them out.
Total of 6 screws including the 2 to remove the dash.
The bulbs are on the back of the cluster. Just twist out, and twist in.
What color do you want? There's a blue film on the gauges. You will have to remove that unless you want blue.
JRhodes88 (06-15-2011)
Also, where can I purchase the replacement LED's? I've ordered from V-LEDs before, can I go there?
I've replaced my clock light and many other lights back there and it's relatively easy if you are patient and have a helper with small hands. That just involves removing the large plastic "front" of the dash. But to get behind the gauge cluster, you'll have to remove the cluster itself as Karanx7 mentioned. I actually would like to figure out how to get the plastic away from the gauges sometime so I can extract a dead gnat. So let me know what you find with respect to accessing the gauge faces. I would love to get that gnat out of there but don't want to waste my time if the plastic is not separable.
00 ssm
The cluster isn't sealed. The plastic cover is held in by clips. There's maybe 6 of them. It's all plastic and the clips can break somewhat easily if you're not careful. I broke 1 or 2 when taking mine apart but it's still holding together just fine so you wouldn't be screwed if you broke a couple.
Unregistered Member
I just want something to match the rest of the LED's that I have in my car (like the dome light). What do you mean there is a blue film on gauges? They are kinda yellowish lights now behind the gauges.
So they added a blue film to the gauges. Blue film + Yellow bulbs = Vomit green color.
So if you want red or something, you will end up with a purplish (red + blue = purple). If you want blue, you don't have to mess with the film. Keep in mind, you will get a light blue if you install white LEDs.
If you have a TL-P, I can guide you through the blue film removal. If you have a Type-S, your probably gonna break it, so I'd rather you didn't try.
JRhodes88 (06-16-2011)
00 ssm
There's a video from OntarioTL which shows how to clear the film off. If you were curious.
https://acurazine.com/forums/showthr...cluster&page=6
All the bulbs on the TL are regular bulbs (not LEDs). Those bulbs light up yellowish like you said. However, the retarded designers of the TL decided, "Let's make our gauge color vomit green."
JRhodes88 (06-19-2011)
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
