Synthetic Oil
Synthetic Oil
Hey guys I did a search but I could not find anyone in my area. I live in Miami where it seems it is alwalys hot. What Synthetic Oil would you recommend I use? I am always running my car hard so I wanr to make sure I get the right one.
i run Mobil 1 5w30. its more than adiquit. my car idles all day long and im on 15k change intervals
m104 or 105
I'm also using Mobile 1 5w30 every 7-10K miles. Its been working great, synthetics can take lots of heat. The oil is good for longer, but its the filter that can get clogged. I used to use the Mobile 1 filter M1-105 (longer one and wider, but oil seat ring is the same diameter as stock filter) vs the catalog recommended M1-104 (exactly the same size as the Acura filter). Use can also try the M1-208 (same width, but longer).
However after doing more research, I found a lower cost and still very good filter - the Puralator Pure One PF-24458 (blue not the white filter). At $6 at Pep Boys vs $12 - 14 for the Mobile 1, you can change more frequently. The Mobile 1 filter is very solid and can take hits, where as the Puralator casing is not as solid. But in actual driving, I never hit anything with the filter anyway, and its filtering is rated very high. This PF-24458 is also longer, so it has more filter area which is better. Be sure to check in the box for the metalic dark blue color filter, since I find that guys switch the white $3 filter in the box for the Pure One higher end $6 model.
Higher number = more viscosity = more engine protection.
The main reason why Honda / Ford use 5W20 is so that it can get marginally better fuel economy. I think I'm gonna switch to synthetic soon ... go every 12000km per oil change (VS every 6000km on conventional oil).
This topic has been talked to death. Thread closed now.
IBankMouse
06-13-2020 12:53 PM
lanechanger
10-13-2015 10:56 AM
