Sway bar DIY?
Sway bar DIY?
I bought the Eibach front and rear sways & all 4 new moog end links. My question is... Is the install pretty straight forward becuase I did not see a DIY out there unless I missed it. Any advise for when I do the install? Thanks in advance.
kill you till you die
Definitely straight forward, take a look at the stock ones...pull off a wheel and take a close look at the endlinks, sometimes when you try to break a nut free the whole assembly will spin so you have to hold it with some pliers. The rear should come right off, I'm not sure if anything blocks the front one.
the front is going to be a pain!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
the rear is easy.
the rear is easy.
the rear is easy.
the rear is easy.
Also is there any hardware (bolts that will be reused that may be rusted that I can prepare for and buy in advance in order to put on new when reinstalling?)
Thanks!
It's the Halladay season!
Get the car as high as you can, safely. The front is a bit harder than the rear. Getting it in and out is like a puzzle, but absolutely doable.
I'm 99% sure sway bars are technically suppose to be installed with the suspension loaded. I did it without load (I'm sure others have also) and it was fine.
If you live in a rust prone area, be prepared to cut your endlinks off and replace. Moog is a very good beefier replacement.
Good luck!
Good luck!
So what is the preferred way? With the suspension loaded or not loaded? If loaded, where is the best plact to put the jack, or will ramps work? Thanks
Front is not a pain. It like said above with all its bends needs to be twisted (you will see as you are removing it) to get it out.
As for the car. Jack it up from the front lift pad (on the subframe just below the front engine mount, and in the rear the little loop that hangs down on the spare tire well) and place jack stands on the factory lift points.
Completed it on Saturday and all I can say is WOW. Feels like a whole different car. Best $250 I have ever spent on a car.
The rear was easy. Front did take a bit of time to wiggle back in (and finding it was easier to put the endlinks on the front sway bar before trying to do it once in place.)
Found it was much easier to heat the endlink joint to the point of it poping out and then using a vice on one side, and an impact on the other to get the bolt out.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
to get mine off i just hit them with a hammer separating the end from the link allowing me to get a vicegrips on it to hold it from spinning.
difference btw Sway Bars & Sway Bar links?
I am trying to replace my sway bars, for my 01 RL.
Whats the difference between sway bars and sway bar links?
Does anyone have some Pictures of these 2 items?
These noise is driving me crazy.!
Thank you
Thank you
Tennozan (02-13-2012)
AZ Community Team
Received 7,770 Likes
Sway Bar:
A sway bar or anti-roll bar or stabilizer bar is a part of an automobile suspension that helps reduce the roll of a vehicle that is induced by cornering or road irregularities. It connects opposite (left/right) wheels together through short lever arms linked by a torsion spring. A sway bar increases the suspension's roll stiffness—its resistance to roll in turns, independent of its spring rate in the vertical direction.
.... A sway bar is usually a torsion spring that resists body roll motions. It is usually constructed out of a U-shaped steel bar that connects to the body at two points, and at the left and right sides of the suspension. If the left and right wheels move together, the bar rotates about its mounting points. If the wheels move relative to each other, the bar is subjected to torsion and forced to twist. Each end of the bar is connected to an end link through a flexible joint. The sway bar end link in turn connects to a spot near a wheel or axle, permitting forces to be transferred from a heavily-loaded axle to the opposite side.
The end links connect the sway bar to the rest of the chassis/suspension.
BTW - if you're driving an RL, you probably want to post in the appropriate RL section.
Told Ya'LL...DYNASTY !!
Def go with moog, nice beefy replacements... Did my front eibach this weekend... Def a lot easy with 2 people.. Actually took less time then my rear because my end links came out first try... Got lucky... Let some pb blaster soak in for 10 mins and held the end links side with pliers while taking off nut... Also jus twisted out like a corkscrew towards one side.. Nice and easy!!!
![](http://img600.imageshack.us/img600/7640/img2412lb.jpg)
Just got it done, about 2hrs. Easy and no complications, definitely helps to have another set of hands in there for ease though. Feels great going into and coming out of turns!
the rear is easy.
the rear is easy.
The front is just a little weird to route but not that bad.
The hardest part is to remove the old links if their rusted on.
I just broke the old ones off the bar and put a vice grip on the ball socket and just break that nut off with an impact.
Both are pretty easy to do since it’s bolt off bolt on.
I do agree, the other big concern is being able to remove the endlinks, which I've see the DIYs, but can be a pain to break off.
also, what year and trim TL do you have? just making sure it is consistent.
2003 TL-S
Disconnect the end links and then unbolt the stabilizer bar bushing brackets from the rear subframe. The bar will then drop down and rest on the exhaust pipe.
The hardest part is maneuvering the old stabilizer bar out and the new one in around the exhaust pipe and suspension components. I did it with the front of the car up on jack stands.
