Suspension Problem..need help
Old Mar 12, 2007 | 01:52 PM
sittinlow's Avatar
not sure if this is the right thread, but anywayz,
I was drivin to work this morning and i kept hearing a squeaking sound coming from my front driver shock(tein basics) whenever the car shakes from a pothole or something. then all of a sudden it gets woarst. It starts to rattle hard like the the suspension is gonna fallout or something. anywayz i go to check it and the strut is raised up like its about to hit the hood. any ideas of what happen, i think the strut mount is broken. I drove to work, with the hood not locked incase it raises up too high, i just hope i can make it home.. here some pics.
Old Mar 12, 2007 | 02:03 PM
01tl4tl's Avatar
Hmmmm Did you put those in yourself?
Regardless call Marcus from MrHeelToe he knows Tein and will be able to look up this thread and help you.
Looks bad to me
his # 1-949-295-1668
Old Mar 12, 2007 | 02:07 PM
sittinlow's Avatar
yeah i installed them myself more than a year ago.. thanks alot though. I spoke to one mechanic and he just looked at it and said the mount is broken..
Old Mar 12, 2007 | 02:11 PM
01tl4tl's Avatar
There you go then- dont drive it that way is my suggestion
Did you recently encounter any potholes or other bad things?
Old Mar 12, 2007 | 02:43 PM
sittinlow's Avatar
I cant remember hitting anything serious.. but with these ny roads, i probably did..if it is the strut mount, do i have to remove the whole suspension to fix it? and where is the strut mount located?
Old Mar 12, 2007 | 04:21 PM
01tl4tl's Avatar
After removing the tire the damage should be staring at you
No telling for sure until then whats brken where, but I would expect to remove the entire strut/spring and if the top mount of it is broken, tear down and new tophat
Old Mar 12, 2007 | 04:34 PM
fsttyms1's Avatar
Did you reuse the factory tophats with the tiens or did they come with their own?
I wouldnt drive it. At all. It will cause more damage and possibly come thru your hood
Old Mar 12, 2007 | 06:40 PM
sittinlow's Avatar
if the tophats is that black peice that closes the coilover and has those 3 bolts in it that goes into the body of the car.. then yes I did?? I parked the car, on the way home i noticed it got alot higher like its touchin the hood now..
Old Mar 13, 2007 | 11:40 AM
sittinlow's Avatar
i checked the strut mount and it seems fine.. any other ideas guys??
Old Mar 13, 2007 | 01:01 PM
sittinlow's Avatar
thanks guyz i fixed it..it was a washer
Old Mar 13, 2007 | 01:04 PM
thAviEtbOi 37's Avatar
When i installed my coilovers the first time I had a similar if not the same situation.
I would suggest taking the whole coilover on that side out and see if there is any damages. When this happened to me it was because I for got to put in one of the washers, but you said you had these for a year and I assume that this is not the case.
Regardless, I think you should take it out and see if there is what is wrong
Edit: dang you beat me to it
Old Mar 13, 2007 | 02:50 PM
01tl4tl's Avatar
Pic Please
Which washer was the culprit- what did it take to fix?
Old Mar 13, 2007 | 04:18 PM
etxxz's Avatar
@ slide or die @
maybe the top hat just gave out....i dont see how but regardless of what it was you STILL have to take the coilover out of the car to get to this hat so...get to it you can't drive it anyways. peace
Old Mar 13, 2007 | 07:57 PM
sittinlow's Avatar
this washer holds the strut pole down. it broke and the pole was just sliding between it.. i took off the whole coilover and the top off and saw it... i bought a bushing kit for 7bucks and it came with washers n so on. so i just changed that washer..
Old Mar 13, 2007 | 08:47 PM
Black-Balled's Avatar
WILL PLAY POOL FOR CASH
NIce to hear it was a relatively painless fix- other than the worrying part!
Now get you some shoes!
Old Mar 13, 2007 | 08:50 PM
sittinlow's Avatar
LOL.. i jus ran out to take those pics when i saw the post askin for them. HAHA.. but yeah the fix was pretty easy....
Old Mar 13, 2007 | 09:13 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
good to hear...before clicking on the thread i got a little sad:
"suspension problem...need help....sittinlow" <here we go>
Old Mar 14, 2007 | 01:33 PM
sittinlow's Avatar
^^ LMAO..thanks bro..LOL..
Old Mar 14, 2007 | 01:37 PM
CL Platano's Avatar
Tristate ViP Crew
now you must raise your car
Old Mar 14, 2007 | 01:51 PM
sittinlow's Avatar
HAHA... im sure we all kno thats never gonna happen Ray...but thanks for the suggestion..besides then ima have to change my plates.lol. anyway lemmi stop before i get in trouble by the mods for rambling .. thanks for all your help guys.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
