Sudden Decrease in MPG
Old 09-03-2013 | 08:09 AM
  #41
fsttyms1's Avatar
Originally Posted by ProjectAcuraTL
if you guys are gettign 400+ on highway then what is wrong with my car? is it the 4 speed (D4) tranny becuase all of your guys cars are 5 speed (D5). i havent clean the EGR and i remeber when i had the car at 73K back in 2009 i used to get like 350+ MPG and in 2011 when i had 105K i got the timing belt and etc all changed and i have noticed a weird ticking sound when i am in a parking garage, which sounds like ticking vavles. So would that effect my MPG?
The 4 speeds got that too. Im 6 speed now and get the same mileage as i did with the 5 speed even though im 750 rpm higher on the hwy.
Tires can make a huge impact on mpg, Pressure in them as well. Dirty EGR ports, aging or bad o2s, dirty fuel injectors, valves that need adjusting, spark plugs. Your ticking, where is it coming from, drivers side near the firewall or the engine?
Old 09-06-2013 | 09:59 PM
  #42
Big Cope's Avatar
Originally Posted by fsttyms1
Ill Ask Again
What is enough and not too much????
It depends on your tires. I'm running 19" tires.
Old 09-06-2013 | 10:18 PM
  #43
Big Cope's Avatar
Originally Posted by Skirmich
I still get +440 miles on highway only, Cruise set at 80mph.
Tires set at 35-37psi always.
Wow!! 440 miles hwy at 80mph!! I can run the same speed and only get 360. What are you getting city then?
Old 09-06-2013 | 11:49 PM
  #44
Skirmich's Avatar
^^ I get around 32Xish but lately I got around 31Xish since my Valves need works ASAP or could be the above normal hot days between 90-103°F...
Old 09-07-2013 | 07:07 AM
  #45
Nicks2001tl's Avatar
I'm getting a solid 350 mpg for my daily driver.
Rare long trips around 400 mpg.
Old 09-07-2013 | 12:59 PM
  #46
fsttyms1's Avatar
Yes, i know. Im running 255/35/18 with 38psi for normal driving, 42 for hwy (when i know im going to be traveling)
BUT, Its a simple question. What PSI are you running. What is "Enough, not too much" Yes, every tire has a max psi rating and many are different from each other. But the question asked wasnt what is the tires max psi, its What is ENOUGH, NOT TOO MUCH = in PSI
Old 09-08-2013 | 10:00 AM
  #47
Big Cope's Avatar
Man I don't know. I'm not that meticulous about the air pressure in my tires. When I put air in I check the tires (Nexen N 3000) to see what the max is and get close to it.
Old 09-08-2013 | 10:01 AM
  #48
Big Cope's Avatar
How do you know if your valves need work?
Old 09-08-2013 | 12:15 PM
  #49
Gabru678's Avatar
I get 21.17 MPG with my 225/35/18's (Michelin Eagle RSA's) on 90% highway. And I have a max PSI of 44 but have it set at 46-47 on the rears (nothing ever in the rear seats or trunk) and 44 in the front.
I think you will know you have too much PSI when the ride gets awfully stiff around town and on potholes. I am always on the high way so I dont feel it too much unless I am around town.
Old 09-08-2013 | 07:18 PM
  #50
Air pressure in tires..You start with the manufacturer recommendation and go from there never going lower then that spec and check your tire pressure regularly. For ex: After a few fill ups or when the temperature changes drastically like too hot, your tire pressure can change up to 4
psi.
Valves will start clicking and then you know they need to be done or just do it to get it done with.
Note: Valve adjustments are a back breaking job.....
Old 09-08-2013 | 09:33 PM
  #51
Skirmich's Avatar
They are ticking hard, More than I'm used to hear..
Old 10-12-2013 | 09:53 PM
  #52
MrMoAcuraPar's Avatar
my 99 TL-P gets 380-400 hwy per tank using 93 octane, it needs plugs, CEL is on, 1/2" taller tires than stock (on TSX 17's), and 217K on the odo.... almost time for TB/Water pump, valve adjustment.... I baby it because its on its 2nd/3rd tranny, G'Ma was kinda fuzzy on the details when she gifted it to me in '11, so I drive a bit "scared" lol
Only engine mods are Stage 1 exhaust and CAI-why tempt fate and fiddle with near-perfection?
Last edited by MrMoAcuraPar; 10-12-2013 at 09:56 PM. Reason: I'm a Dumbass and hit reply before my thought was finished.
jdmaszfcuk
10-19-2015 12:31 AM
Skirmich
10-01-2015 12:59 PM
hashbrown
09-29-2015 12:13 PM
Froid
09-27-2015 06:16 PM
rboller
09-23-2015 02:49 PM
Quick Reply: Sudden Decrease in MPG
