Success Rate on Recently installed Tranny's
Originally Posted by fsttyms1
I dont believe the newer updated parts were available or installed yet
Do you know exactly what was updated? How do I know if I'm getting the updated tranny (mine is being replaced right now)?.
Originally Posted by zibadun
I've read somewhere that the newer honda models, with fly by wire, have a more reliable transmission because engine power is reduced during shifting which puts much lower wear on the parts, but the transmission itself is basically the same.
The clutch plates, drum and a shaft were updated to allow better cooling and less friction. I dont know if there is a way of knowing, other than the ones done after Feb of 05 (i believe) are the ones with updated parts
i dont buy into the drive by wire making them last. It was a bad design with inadiquit parts.
"5-Speed Automatic Transmission for V6 Engines
...One difference from the TL transmission is the addition of the ETC system to further enhance shift smoothness by momentarily closing the throttle (reducing torque) at shift points."
http://www.hondanews.com/CatID2006?m...37574&mime=asc
I don't know much about mechanics but removing torque for a brief moment while the gears shift sounds like an interesting idea. It seems this will reduce load on the clutch and on the gear teeth (?) while they are locking into place. Of course acura says they do to for better shift comfort. Here is the source, this is for accord but probably applies to newer TLs:
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Skirmich
Sep 15, 2015 06:41 PM
