Strut Bar
Strut Bar
I'm curious to know where to buy and what strut bars are good but still decently cheap. I'm also curious to know if a progress RSB is as good as people say and where I can buy one.
the frame crossbar between the strut towers on top of engine, you can add additional suppurt with a cusco bar
more important is a lower frame crossbar- cusco- see MrHeelToe threads in the Black Market Sponsored Sales or www.heeltoeauto.com
has sway bars too, or you can upgrade the current bushings and sway bar end links
KatabaticSaint (07-08-2011)
Progress RSB for the 3G TL is nice. The initial hard turn and weaving in a parking lot after you install it will blow your mind. I got used to it after awhile. Would have been nice to drive a stock 2G to re-feel the difference again.
My setup was:
Wider grippy solid tires + lighter wheels (rpf1s) + coilovers (tein ss-p) + strut braces + progress rsb = much better handling glorified Honda Accord.
(Pretty sure I've written an identical sounding post on this subject before.)
I scrape ~sometimes~ but the bar also protects the cat as it hangs slightly lower than it
better an 80 dollar bar loose some metal than an expensive order thru excelerate and install a new cat. Bar still performs the same minus some paint
learn to cross bumps and dips at an angle- that reduces most of the problem,
except those really bad driveways or wide speed bumps
Cusco front upper and lower. You'll notice the lower bar more - feels more solid when you got over bumps at highway speed. *NOTE: It hangs ridiculously low. If you've lowered your car, you'll scrape everything. I went through 2 lower braces before giving up on them.
My setup was:
My setup was:
2003 TL-p
i see XLR8 now offers a front sway bar made by ST, but its 22mm and doesnt seem to be large enough. has anyone tried the ST front sway bar?
i currently have progress 24mm rear sway bar, and B&G sk2 shocks and springs. the car handles great and is flat, the front could be tighten up a bit thats all.
what brand and size front sway bar do you have? Eibach 27mm? does installation require dropping the exhaust?
lanechanger
10-13-2015 10:56 AM
