Stock tires DO suck!
OK, after 6100 miles on the TL-S I finally understand what people mean when they say that stock tires suck. I'm starting to notice more and more that the tires start to squeal when I take corners hard. The car itself is hardly leaning or losing control, but the tires are on the edge of their grip envelope. Now I'm not keen on drifting around highway on-ramps, so I definitely think that the stock tires need a lot more grip to match the rest of the car.
Yup, the tires do suck. And I think they are all weather, and I live in a hot climate. Anyhow, if I'm changing tires, I think I will get wider and lighter rims also.
Anyone know of ligher wheels, and how heavy these are?
I think I'll wait for the factory tires to wear out (probably about 40,000 miles or so) before buying new shoes for the TLS. I definitely want all-weather tires because Kansas weather is very unpredictable, and we do get moderate snow here. I don't think I'll change my wheels either, unless I get a really good bargain. Any suggestions?
Well either way, these tires must go. I have some yokohama AVS Sport Decibls on my Vette, these have great wet and dry traction, nice thread design, and make no tire noise at all!!
Only other tires I have tried for a perfromance car. Most of the goodyear stuff was not too hot and just over priced.
The Yoko AVS DBs are going on my wife's Altima (size issue). I've only heard great reports on them.
AS far as lighter wheels, the SSRs on my car weigh about 14 lbs per wheel and Volks (and others) make some nice lightweight forged wheels. Expect to pay $$$ for well made lightweight wheels. (lots of benefits – acceleration, handling, road feel, etc)
Not a Blowhole
Yeah, invest in some 16" steel wheels and get snow tires, and good summer rubber for the rest of the year. I switch over to my SSR's.
If you must "all-season" (which means you have a compromised tire all season) consider the BF Goodrich's and the new Dunlop A2.
Not a Blowhole
I can peel out in my Yugo??!!! Hell, I have been lookling for a reason to dump my TLS and get back in my sporty Yugo ride. Now, I have had some part on order for a while from Milosevic Autoparts...guess that is what happens when one buys a car from a country heading toward civil war.
I hope I do not have the same problem with my Taliban 2000 goat mobile.
I hear the F15 customized Afganmobiles are going to be a real HOT item also
From experience I can tell you that Toyos handle much better, HOWEVER, they are much louder than the stock Michelins! Plust the tread life on the Toyos is questionable in my opinion. I have put about 12K on mine the front tires are worn down.
Anyone had any experience with the Dunlop Sport SP 5000's or the Yoko AVS DB's?
Also will the stock TLS rims take a 215/55/17 tire?? What about a 225/45/17 tire? I'm new to this tire sizing science so bear with my ignorance.
Main objective is to improve the ride quality and reduce tire noise, hence the Dunlops & Yoko's.
Purchased: April 28, 2001
Here is a simple formula for guesstimating tire size, it is not completely correct since the rim width can play a large factor in actual tire height since the sidewalls may be stretched out or compressed in to fit the rim. Anyway, here it is:
((Wx(P/100)x2)/25.4)+R = H
W = tread width in millimeters (215, 225, 235, etc.)
P = tire profile in per cent (35, 40, 45, 50, etc.)
R = rim diameter in inches (16, 17, 18, etc.)
H = overall tire height in inches
i.e. 215/50/17 = W/P/R = ((215x(50/100)x2)/25.4)+17 = 25.465
The answer will be the overall tire height in inches (or at least pretty close).
If you don't want to do the math, here are a few standards that may fit a TL-S:
205/60/16 = 25.685 (stock TL)
215/50/17 = 25.465 (stock TL-S)
235/45/17 = 25.327
245/45/17 = 25.681
225/45/18 = 25.972
245/40/18 = 25.717
215/40/19 = 25.772
235/35/19 = 25.476
http://www.tirerack.com has some good brand-specific data on the tires they sell.
It is very important to stay close to the factory tire size or else major safety systems in your car could fail, ABS, VSA, VTEC, etc. All of these systems rely on vehicle speed sensors to function properly. Not to mention throwing off the speedometer and subjecting you to the possibility of speeding accidentally instead of on purpose.
235/45/17 = 25.327
245/45/17 = 25.681
225/45/18 = 25.972
245/40/18 = 25.717
215/40/19 = 25.772
235/35/19 = 25.476
This link will return equivalent tires in varying wheel sizes and profiles; it is an alternative to the Miata tire calc link...
http://www.dsm.org/tools/tiresize.htm
but if u check out the price on our stock tires.that will cost a bit expensive on each one...it is not a zr tires does not mean that tire is suck.however.i do feel our stock tires are pretty cool..at least good for all seasons.
jbrown, edgalang, pianoman41, EricL ..... thks for the feedback.
Am I correct in assuming that the lower your tire profile the more tire noise & road feedback you're going to have? So if you went from a 50 to say a 45 or 35 wouldn't the ride quality suffer considerably.
My dilemna here is that i'm trying to decrease tire noise and improve ride quality. In a perfect world all roads would be glass smooth and you could go with the lowest profile tires possible without thinking twice. The reality is that the the roads around here really suck, not to mention the've decided to dig up half the roads around where I live all at the same time.
So I guess my question is, given the stock TLS rims .... can I play around with tire sizes to improve ride quality? Or am I better off sticking with 215/50/17's?
I had SP5000s on my Integra GSR. I only put a 1500 miles on them before I sold it, (to get the TLS! ) but I liked them overall. The tires were pretty quiet, good wet/dry traction. I did think they made me feel a little removed from the road though, more like a touring tire than a High Perf. tire, IMHO. They did hold the road well, just noticed a little delayed steering response. It could have been due to the newness of the tire though
I dropped to 45's and when these are worn out, I will seriously consider going back to 50's.
O.G.
Originally posted by Xorg
I put a set of Falken high performance tires on the my TLS, and the difference is noticable. A bit more road noise, but the grip like crazy.
After the stock tires wore out, I put Pirellis on both my Acura and BMW (P6000 Sport Veloce all-season on the CL and PZero on the Bimmer). I have been very happy with the performance, ride comfort, noise level, and wear of those tires. When you go shopping for Yokohamas or Toyos or whatever, take a look at Pirelli, too.
1fatcrxnem1
22
06-01-2018 01:23 AM
