stock exhaust specs
stock exhaust specs
I need a measurment of the stock exhaust to know how much pipe to order. can anyone help? i need from the cat back to the mufflers. or if any one knows the ammount i would need like 8'? 12'? Thanks in advance
Are you having the pipe bent or are you buying bends? Are you doing the work yourself or having someone do it? How much pipe you need depends on what your doing. Are you going to the stock Y or making your own and going to the mufflers?
Need more info.
Need more info.
if you're fabing this stuff yourself, you should get under the car and start measuring. Its gonna be your design, you need to get under there and start thinking where you want stuff to bend and such. Theres really no one who could tell you how much to get except yourself.
when i worked at meineke mufflers we had a mandrel pipe bender, we would just look up the measurements. slip this thing that was like a level over the very end of the pipe. it was circular with degrees on it. you'd just bend where the measurements told you to, then turn the pipe to whatever degree, bend, turn, bend, turn, ect...
im prolly not explaining it well, but man it was super cool and not that difficult to use at all.
