Stock Amp
Old Feb 8, 2006 | 09:37 AM
CL Platano's Avatar
Tristate ViP Crew
Stock Amp
How many watts does the stock amp push out? I'm planning on change the sub but wanted to know if I can get by with the stock amp for now.
Old Feb 8, 2006 | 09:43 AM
georgy_d28's Avatar
The amp for the sub is 100 watts
Old Feb 8, 2006 | 10:35 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
100w dedicated amp. The speakers have their own.
Old Feb 8, 2006 | 10:49 AM
youngBuk's Avatar
buy a new amp and a sub. if u get a new sub with the stock amp the bass will still sound the same.
Old Feb 8, 2006 | 11:17 AM
Da_iLLeZt_TL973's Avatar
Future JDM Whore
if you get a new sub and run it on the stock amp wouldnt you blow the stock amp....not only that it will sound like shit i would think
Old Feb 8, 2006 | 12:15 PM
SSMTL01's Avatar
I disagree- It will not bump harder but will sound cleaner/less muddy. But it really is just better to take that POS out and run a seperate amp/sub.
Dvs rice's Avatar
is there anyway to change that stock amp. is seems like the stock sub is underpowered as well as the Bose speakers.
Old Feb 8, 2006 | 12:33 PM
CL Platano's Avatar
Tristate ViP Crew
what is the size of the stock bose ?
Old Feb 8, 2006 | 12:40 PM
BIG_KOUT's Avatar
I left the stock Bose speakers in cuz u really wont get an aftermarket set up that'll sound much better, for the money your gonna spend. Once you disconnect that stock sub and put a new one in your trunk with a new amp to push it you'll be like ahhhhhhhhhhhhhhhhh
Old Feb 8, 2006 | 01:08 PM
CL Platano's Avatar
Tristate ViP Crew
I'm not buying new subs and amps so I won't be spending too much. The black market is my friend
Old Feb 8, 2006 | 02:02 PM
Dvs rice's Avatar
i believe it is a 8 or 9 inch sub
Old Feb 9, 2006 | 09:22 AM
bdturbo's Avatar
Its a 9" sub, you cant replace it without getting one from Acura.
Old Feb 9, 2006 | 12:26 PM
BIG_KOUT's Avatar
I didn't take my stock sub out, thats too much work, I just disconnected the wire when I put in an aftermarket sub/amp set up
Old Feb 9, 2006 | 12:32 PM
CL Platano's Avatar
Tristate ViP Crew
Well I bought an 8" kicker from a member and he gave me a mount and dynamat for it. I'll try and hook it up tomorrow and see how it sounds.
Old Feb 9, 2006 | 12:43 PM
cobrajjf's Avatar
I tried replacing the stock Bose sub with an 8in. MTX and using a different amp, it was a disaster. It sounded horrible, it was louder, but the whole rear deck started to rattle if you turned it up at all, not to mention, the Bose sub is a special type that doesn't require a sealed box, it's called free air or something. I would say go completely aftermarket with a sub and amp in the trunk in a sealed or bandpass box, the people at Acura designed the system the way they did for a reason.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
