still getting shitty gas mileage
Old 06-26-2005, 10:29 PM
Liftedoff420's Avatar
i changed the oil to synthetic, changed air filter, put air in the tires, and added gas treatment and fuel system cleaners, and i use 91
i still get like 16mpg in the city....im starting to get pissed, i used to get like 28 on the freeway and on my last freeway trip i got like 22....usually i get 19-20 city
do you think the fact that i got my car lowered and didnt get an alignment has any effect on gas mileage? what else can i do? i barely get 200 to the tank when driving in the city, and i rarely take the car above 3000 rpm
Old 06-26-2005, 10:42 PM
Dragging knees in
Pure Adrenaline's Avatar
1. Heat and humidity kills fuel mileage.
2. Check the FPR vacuum hose. Take off the engine cover and you will see a hose on the rear bank of the engine, running parallel to the engine (sideways). Somehow mine blew off a while back, and the PCM thought I was losing fuel pressure. So it was adding 27% more fuel than normal. As soon as it was reconnected and I cleared the logs by disconnecting the battery, my fuel mileage went back to normal.
Old 06-27-2005, 01:13 AM
TeknoKing's Avatar
thats pretty bad mileage, i get 200 for a half tank and i drive city/highway about 50/50.
do you have a heavy foot? how is your air filter? wheel balanced? proper PSI? and u should defnitely get an alignment. Do you leave the car running idle for long time? A/C use? Spark Plugs? it can be a lot of things...
i had that problem before, I had to get a new Fuel Controller and a PCM (comes as a damn kit)..also my fuel injectors were a little misaligned so I aligned them and made them a bit looser...so far soo g00d.
good luck man.
Old 06-27-2005, 03:01 AM
dont have a heavy foot at all...rarely take it above 3000 when i come off the line....most of the time ijust cruise
brand new air filter
just changed oil to synthetic
wheels balanced
tire pressure was done
never use AC
live in SF so its almost always cold out
elaborate on this hose thing? if the hose is discconnected i just reconnect it, then kill the battery to reset the computer?
Old 06-27-2005, 03:10 AM
Dragging knees in
Precisely. Once you take off the plastic engine cover, it will be obvious to find a loose hose. It's a remote possibility.
Old 06-27-2005, 09:21 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
there may be a number of things. if you continue to have bad mileage you may want to make an appt at teh dealer to let them diagnose the system while its running. there may be a o2 sensor thats sending the wrong signal? there are a ton of sensor, and vacum related things that are possible. my car idles all day long and i get typically 170-220 per half tank (depending on how much hwy driving i do)
Old 06-27-2005, 05:24 PM
njzprettyboy's Avatar
you may wanna trade for a tsx..ive read that gas is gonna go up again soon
Old 06-27-2005, 07:48 PM
crazym0nkey's Avatar
Maybe you're driving more in the city than on the freeways lately? I used to (and still get) 16-18 mpg and thats with about 80% city. Lots of stop and go traffic in SF streets. But I do get 29-30 mpg on freeway when I drive from SF to Riverside (near LA) so I know theres nothing wrong with my car (at least I dont think).
Old 06-27-2005, 10:06 PM
NYCdesiPola's Avatar
Wink
good luck man.
bro..it is impossible to get 200mileage in half tank....what do you mean by ( made them a bit looser )? with a full tank of gas l onlt get 200 miles in 99TL tell me how you done that...thanks
Old 06-27-2005, 10:16 PM
2Poor 2Furious
t0ast's Avatar
Check your spark plugs. In my SUV, I just changed the plugs after having NEVER changed them for 110k miles, and I instantly gained 20% of the gas mileage back. The gaps had worn down from 0.04" to 0.065".
Old 06-27-2005, 10:20 PM
05 C230K & 09 135i 6MT
03CoupeV6's Avatar
No, it is not impossible. How can you make such a statement?
In a recent trip I took, it was 232 miles when the needle finally dropped to the little line below the bold half-tank mark. Of course, by this point, I was at my destination and the rest of the tank was city mileage. That tank yielded 403 miles.
Old 06-28-2005, 09:04 AM
fsttyms1's Avatar
its not impossible to get 200 to a half!!! i do it 95% of my driving. if its all hwy its usually closer to 230 to the half.
Old 06-28-2005, 10:42 AM
I need 2 more gears
sbuswell's Avatar
i get 200-230 at half then 100-120 on second half. Most cars the first half tank shows higher mile.
Old 06-28-2005, 10:48 AM
VTEC11's Avatar
Not impossible for the highway, but it is for the city.
Old 06-28-2005, 12:35 PM
03CoupeV6's Avatar
Definitely, I got about 230 at half on a recent highway trip. Although I'm still jealous when I go on trips in my friend's Camry and it's still above half-tank at 293 miles (YES, I didn't believe it until I saw it for myself)
Old 06-28-2005, 04:33 PM
bitemeeh's Avatar
I just hit 380 miles on a full tank then my gas light came on... 03TLS
Old 06-28-2005, 05:17 PM
I pimp an Audi A4.
pimpravi's Avatar
99TL's eat up more gas.. i BEARLY get 300 per tank
Old 06-28-2005, 05:35 PM
03CoupeV6's Avatar
Maybe it's the four vs. five speed auto.
Old 06-28-2005, 06:35 PM
MikePA's Avatar
Here we go again...the meaningless 'miles per tank' discussion.
Old 06-28-2005, 06:37 PM
fsttyms1's Avatar
my lawn mower will mow my lawn twice to a tank!
Old 06-28-2005, 06:41 PM
MikePA's Avatar
A friend just bought a Ford Excursion and he gets over 500 miles per tank!!!!!
Old 06-28-2005, 06:45 PM
Dragging knees in
I can sacrifice some gas mileage if that meant avoiding driving a car with no personality whatsoever.
Camry = vanilla
TL = chocolate chip
Old 06-28-2005, 07:10 PM
fsttyms1's Avatar
and costs him 100.00 to fill it
Old 06-28-2005, 07:21 PM
03CoupeV6's Avatar
Camry = vanilla
TL = chocolate chip
I actually have nothing but respect for the Camry. It's a 1998 model, and that same year model Camry saved some loved ones back in 2003. They were in it, stopped to turn on a 4-lane highway, when a big Avalon hit them from behind without slowing down. It knocked the Camry into oncoming traffic where it was hit three more times by two cars and a cargo van - everyone inside walked away unharmed, and the car was destroyed, hit from every angle.
And while you're right, it seems a bit boring, it's a very good car. I prefer to go in it when forced to choose between my TL and his Camry. The Camry rides better, uses less gas, and is every bit as comfortable. The cars are years apart, mine is faster and better equipped, but I see the Camry as a loyal friend and not as a competitor.
Old 06-28-2005, 07:37 PM
Dragging knees in
Oh, I'm not questioning the safety of the car. I know it's a very safe and reliable car. But it's just too boring for me. I am willing to sacrifice gas mileage, safety and whatnot for a little more personality in my car... not that our TL is an unsafe car.
Old 06-28-2005, 08:00 PM
03CoupeV6's Avatar
Oh the TL is definitely safe, I just had to stick up for the Camry. It's a great car, just a boring one. I own a TL and an Accord V6 coupe, so I'm loyal to Honda and don't want or own a Camry, I just have utmost respect for the Camry - and Toyota as a company.
Old 06-28-2005, 08:17 PM
Dragging knees in
Same here. Toyota is a great company and I have much respect for them. But like you, I am also somewhat of a loyalist to Honda/Acura; and the fact that our cars are a little more fun to drive.
Old 06-28-2005, 09:19 PM
1999 Acura 3.2 TL
slikz's Avatar
I get that too.
Old 06-28-2005, 11:50 PM
03CoupeV6's Avatar
I always tell him (my friend) that Toyotas are cars designed for passengers and Hondas are cars designed for drivers!
I always feel a sense of pride, though, when Toyota one-ups the American brands. Second largest automaker and closing the gap quickly.
Old 06-29-2005, 01:52 AM
ok, i just got 334 driving about 80% freeway on my last tank.....so maybe my low mileage is attributed to the fact that San Francisco has so much stop and go traffic that it just eats gas mileage. so i get like 16-18 city, and like 23-26 highWAY...its not that bad
living in the city really sucks.....bad mpg, bad parking, potholes everywhere, crackheads, stolen cars
argh
Old 06-29-2005, 02:08 AM
98tlracer's Avatar
Man im in SF as well and I usually get about 230 to the light. I've pretty much giving up looking for ways to improve the mileage.
Old 06-29-2005, 08:38 AM
SK2003TypeS's Avatar
Stock ?....any Mods ?
Old 06-29-2005, 09:18 AM
fsttyms1's Avatar
just nos
Old 06-29-2005, 11:31 AM
Nice one
Old 06-29-2005, 12:28 PM
Poleshuk S's Avatar
did u get your tranny recalled yet?
i had very bad gas milage before my tranny fell apart on me
Old 06-29-2005, 03:07 PM
whatwasthat's Avatar
hm... i guess i'm getting bad gas milage too. i'm at half a tank and the odometer says i only drove 120 mi.
Old 06-29-2005, 03:12 PM
fsttyms1's Avatar
Nice one
yea thats for when the grass gets deap!
Old 06-29-2005, 03:23 PM
atokishi's Avatar
What the hect? 380 on a full tank? After reading this forum something is hella wrong with my TL. I've got an 02 TLs and my light comes on usually around 245-265. That's probably 60 hwy/40 streets. 380 on a tank would be amazing...
Maybe I should change my spark plugs like mentioned?
Old 06-29-2005, 03:27 PM
fsttyms1's Avatar
to get that type of mileage with 60/40 would be amazing. i get that when all hwy, not a mix
Old 06-29-2005, 03:35 PM
atokishi's Avatar
I guess that just goes to show that there are so many variables that factor in. I guess if we were that concerned about mileage we would have bought a hybrid or something instead of our TL's.
Quick Reply: still getting shitty gas mileage
