Starting problem
Old Sep 17, 2013 | 01:39 PM
Nemesis TL-S's Avatar
Starting problem
My 03TL-S doesn't always start right up. I don't know why, it has new NGK Iridium spark plugs and runs perfectly after starting. But in the morning it doesn't always start right up. Anyone have any idea why.
It does have a remote starter that I use in the winter and the battery is new. I don't get it.
Old Sep 17, 2013 | 05:54 PM
3.2TLc's Avatar
Have the electrical charging/starting system load tested. Check all of your battery and starter connections. Also check the grounds.
Could be that an interlock is on the edge ?
Old Sep 18, 2013 | 09:49 AM
I've had the electrical system checked and they say it's fine.
Old Sep 18, 2013 | 10:00 AM
Nicks2001tl's Avatar
How many miles?
Old Sep 18, 2013 | 12:25 PM
180,000 miles and after starting it runs like new.
Old Sep 18, 2013 | 04:12 PM
victus1's Avatar
The engine cranks but won't start? Does it always do that after a cold start? Have you cleaned the iacv and egr valves?
Old Sep 18, 2013 | 05:06 PM
3.2TLc's Avatar
Question starting problem.....
....... Do ya know what all was checked ?
Old Sep 18, 2013 | 07:14 PM
No I have not cleaned the iacv or egr valves. I'll check them out. Not sure what the iacv is?
Old Sep 18, 2013 | 07:45 PM
victus1's Avatar
Idle Air Control Valve. Do a search on how to remove and clean with carb cleaner. Very easy job.
Old Sep 19, 2013 | 09:15 AM
Thanks victus1, I'll give it a try this weekend.
Old Sep 19, 2013 | 01:31 PM
Try the simple fixes first. DIY's
~egr valve
~iacv valve
~egr port
~can of seafoam in an empty tank of gas
~1/2 can of seafoam in the crank case before oil change
Note: sounds like somethings gunked up, hopefully that's all it is.
Old Sep 19, 2013 | 05:17 PM
3.2TLc's Avatar
Unhappy Doesn't always start.....
Hey Nemesis, other than the plugs.....have ya done any other recent work on the car ? Did this problem just develop or has it been that way before the new plugs ?
...... While the electrical system may have checked out ok at the time of testing , an intermittent starting issue could possibly be due to a poor wiring connection. The reasoning behind this is that you state that the car " runs perfectly " after starting and running normally without signs of stalling or rough idle. How does the car start up after it's been run and is still warm ?
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
