Starter went bad then good again? Advice?
Old Aug 2, 2008 | 08:51 AM
herCLS's Avatar
Guys,
About 2 days ago, my 99 TL wouldnt start due to the starter (all power was fine, but did not crank over...only single click of the starter.
Well, yesterday, I decided to try cranking it a few times and after 10 clicks, the car started (starter gear catched).
The car has started consistently the last 3 times I've started it...is it normal for a starter to miss then be fine again?
Old Aug 2, 2008 | 10:19 AM
BlackMambaTL7's Avatar
Synthetic Roadrage
Sounds like the starterr is in the process of dying for good. You better get it replaced asap.
Old Aug 2, 2008 | 10:34 AM
01tl4tl's Avatar
a 99- you may have a bad ignition switch- there is a recall for those, and even if it was replaced a few years ago- they can still die.
Call acura 1-800-382-2238 x5 or drop by the dealer and ask them to run the VIN for you- and check any recall items to fix FREE for you~
Old Aug 6, 2008 | 09:23 AM
mdavisii's Avatar
B93P TL Owner
Seems like the starters on the 1999 TLs are starting to reach their life span/usage after 10 years. Your starter is definitely in the process of dying. Mine had those exact same symptoms right before it died for good. Do yourself a favor and go grab another one from the autoparts store. When I opened my old one, I immediately discovered the bushings were all worn to dust. There was nothing to make that spark anymore.
Soul_Deamon
Nov 13, 2018 04:44 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
brandnewcolony
Sep 12, 2015 10:39 AM
BlueAquarian
Sep 10, 2015 02:18 PM
NSolace
Sep 3, 2015 08:02 PM
