Srs light on....please help!!
Old Jan 25, 2009 | 02:38 PM
2000TL-Navi's Avatar
what do i need to do to shut the light off on my dash/cluster.....
thanks in advance..
angel jr.
Old Jan 25, 2009 | 03:03 PM
Rajca's Avatar
wham bam thank you ma'am
i followed these steps, took me two times but it went off
instead of using the MES connector, i used two pieces of wire. connected on to one side and the other to the other side and just touched them together, help if u have two ppl.
http://autorepair.about.com/library/a/1g/bl603g.htm
Old Jan 25, 2009 | 03:44 PM
fsttyms1's Avatar
And if it comes back on bring it in to the dealer. There is a recall and it may be that part. With that light on none of the airbags work.
Old Jan 25, 2009 | 04:15 PM
01tl4tl's Avatar
the special extended warranty on the SRS is 10 years/150,000 miles!!
The service manager says there are several parts covered by it, say 5 of the 6 parts there, and that 99.99% chance it is a warranty covered issue, a safety issue for sure.
Get to the dealer- do not pass go- do not collect a tree on the way
Old Jan 25, 2009 | 10:06 PM
damn.. so with the light on no AIR BAGS!! damn.. will shutting the light with the procedure above.. from Rajca...will the make the airbags work again during an accident... or does this need to be done by a dealer to insure the airbags will work?
Old Jan 25, 2009 | 10:12 PM
01tl4tl's Avatar
it may be a false warning or it may be one of the parts that is covered under the special warranty
If it were my car- straight to the dealer,, and they will find it to be warranty~
Like the SM told me, 99.99% chance its a covered part
Old Jan 25, 2009 | 11:39 PM
Rajca's Avatar
if u clear the light the airbags will go off unless you have a part that failed. i took out my airbag and started my car so i know no parts were bad. clear it my way and if it comes back on then you have a failed part
Old Jan 26, 2009 | 12:30 AM
sounds like a good idea....thanks for the help everyone
Old Jan 26, 2009 | 07:14 AM
totaledTL's Avatar
Originally Posted by Rajca
if u clear the light the airbags will go off ...
The LIGHT will go out.
I had this issue when removing a fuse in the driver's side panel one time to install something. If the battery isn't disconnected before pulling that fuse (don't remember exactly which one it was) the SRS light comes on & stays on.
Old Jan 26, 2009 | 07:34 AM
fsttyms1's Avatar
If you do the procedure and the light goes off and STAYS off they are fine. If it comes back on they wont work again and you have a problem that needs to be fixed by the dealer. You may want to just bring it in and have them see. Like said before, there is a warranty extension on a SRS part that is usually the cause for the light that should be replaced (especially if it triggered the light)
Now if you were working on the car and unplugged something you shouldnt have then i would follow the procedure above and just reset teh system
Old Jan 26, 2009 | 09:30 AM
o i see. thanks..
when i called acura client services..and they told me what recall needed to be done or were done on my TL.. they didnt mention one about the SRS light.. so is this something that cant be tracked by the VIN.. and something electrical that the dealer needs to diagnose to determine if its a recall..
also will the dealer charge me something for them to look at this?
Old Jan 26, 2009 | 01:01 PM
01tl4tl's Avatar
If you did not do any work on the car with the electrical system- then its most likely a problem that is covered by a special `warranty extension`
- its NOT a recall, and unless you ASK the low paid phone person at the 800# to look up extended warranty items- they may not.
What recalls DID they say needed to be done? If ANY recalls get the car in the dealer now!
While its there, the SRS can be checked if the red SRS light is ON while driving
By law they must write an inspection/diagnosis invoice- usually 1 hour labor at the standard customer type invoice rate. That allows them to look at your car.
If its determined to be a warranty problem, a special warranty repair work order is made and the work proceeds. Then its no charge to you at all-the diagnosis fee and repair is paid by acura corp to the dealer
If its a `recall` you are in for- those are totally free to you and are written on a special work order...its always about the paperwork in life eh~
Old Jan 26, 2009 | 01:04 PM
01tl4tl's Avatar
VIN is exactly how it, and all recalls and warranty extensions are tracked- you didnt ask the right question is all!
A start number VIN and end number VIN = cars made between these vehicle identification number sets are covered by ....
Old Jan 26, 2009 | 02:18 PM
well i did take the bezel apart..and the middle counsel...when i put everything back together the SRS light came on and been on... previous to that no light.. so what ima do is reset the light... if it comes back on or doesnt want to shut off.. then dealer it is...
does the above sound like a good idea?
Old Jan 26, 2009 | 03:48 PM
fsttyms1's Avatar
Yes
Old Jan 26, 2009 | 06:29 PM
01tl4tl's Avatar
yes= what you did counts as messing with the electrical system
reset it and see if thats all it needs
Old Jan 26, 2009 | 10:08 PM
thanks
Old Jan 26, 2009 | 10:15 PM
BLKOUT_typeS's Avatar
9th Gear
i have the same problem! where could i find this panel to reset this SRS light?
Old Jan 26, 2009 | 11:19 PM
01tl4tl's Avatar
see post number 2 for the link or kris may have it in the 2nd gen DIY section by now
Old Feb 10, 2009 | 12:11 AM
Skeete32's Avatar
NBP
i have a code reader can that clear the srs light?
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
heykosal
1G RDX Problems & Fixes
Feb 27, 2016 06:43 PM
mugen_kid
Nov 13, 2015 10:38 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
