SRS light is on...HELP!
I believe the Helms manual warns that if the battery is not disconnected and you don't wait at least three minutes before disconnecting or removing the seats then the SRS light may come on. The seats have the side airbags and when you disconnected the wiring harness you disconnected the power to the airbag, thus triggering the SRS light. To err on the side of caution, the ECU is programmed to continue to display the SRS light even if the problem corrects itself because the ECU can't know if the correction was temporary or permanent. Therefore it warns the owner to have the system checked. Although I cannot guarantee it, disconnecting the battery for an hour or so may reset the ECU and if everything is hooked back up right it *should* be okay. Of course, do so at your own risk. Might want some input from others that have reset the ECU by disconnecting the battery and see if they have had any other adverse effects.
Matt
Matt
Originally posted by songoku:
I think the side airbag has nothing to do with SRS light....
Has seperate indicator for side airbag...
Take it to the dealer ASAP!!!
Matt
OK...my SRS light is on. And I checked my airbags and it seems the passenger side is a bulging a little and right side corner is slightly popped out. I can push it back in but the light is still on.
At first I thought that it's because I removed the passenger seats. But I have it back in now and is still showing the lights. Will taking the passenger seat out cause the light to come on and not shut back off? Does the side airbag in the seat have anything to do with SRS light or is it because the passenger airbag is bulging? I will take it to the dealer soon.
2001 3.2TL with Nav
Satin Silver Metallic
Factory Rear Wing Spoiler
2001 3.2TL with Nav
mada51589
05-03-2022 08:54 PM
mugen_kid
11-13-2015 10:38 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
