SRS light always on!
Old May 24, 2002 | 05:55 AM
hchhon's Avatar
Anyone knows what is the problem?
Old May 24, 2002 | 06:20 AM
shawhite's Avatar
take it to the dealer they will hook it up to there little diagnostic machine and reset whatever is causing this problem.....
Old May 24, 2002 | 07:33 AM
I have read that neons cause the sensor to set the light off...I'm not sure if LEDs would have the same effect. Take it to the dealer and have them figure it out.
Old May 24, 2002 | 09:10 AM
scotty_passat's Avatar
maybe something is wrong with the passenger seat...there are sensors i nthere to determine how to fire the airbags in case of an accident.
Old May 24, 2002 | 09:13 AM
tl-kode16's Avatar
Well considering hchhon has put mad LEDs in his car, maybe that's what is setting of the sensors. lol!
Old May 24, 2002 | 09:19 AM
hchhon's Avatar
I went to the dealer to check it out this morning and the technician found no defected air bag sensor or associated electronics. I knew after reading a few post regarding that neon light is interfering with the sensor. I had blue LED wire run from the storage arm rest power outlet through the steering column wheel. I think that was the root cause. It can suck that I can't run the wiring there. Anyone know how to reset the red SRS light by yourself?
Old May 24, 2002 | 09:55 AM
baggsTLS's Avatar
Mr. Self Destruct
hchhon, I posted about this once before, if you search maybe you can find it.
anyway, an installer friend of mine and I experienced this problem many times with Honda/Acura. he finally called the dealer to figure out what the deal was. the cause effecting us was having the battery disconnected too long. (ie anything longer than 30 minutes could cause your SRS lights to come on.)
there are many Honda/Acura specialists that will reset for about $35. I have a helms at home, it may describe the procedure, but usually its tedious, but only takes 5 minutes.
good luck, hope this helps.
Old May 24, 2002 | 10:03 AM
hchhon's Avatar
BaggsTLS,
Do you mind posting the procedure here?
Old May 24, 2002 | 11:12 AM
songoku's Avatar
BlingBling INSPIRE 32V
Told you not to play with electrical device!!! J/K
Just take it to the dealer and make sure no to turn your lights in front of them.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
