SRS light
Old Sep 8, 2011 | 05:39 PM
03TLKEV's Avatar
SRS light
While driving the other day my SRS light went on and has stayed on since. Is this something I need to take to the dealer to diag/ fix? I thought I remembered reading somewhere that there might be a recall or warranty ext for SRS issues. FYI vehicle has not been in accident (at least non were reported via carfax before I bought it from 1st owner). Thanks in advance for the advice.
Old Sep 8, 2011 | 05:46 PM
ego_roots's Avatar
theres a reset procedure in the DIY thread.. should work.. if it turns back on after that, then u hafta bring it in..
Old Sep 8, 2011 | 05:47 PM
03tLsNBP's Avatar
MechEng
Since it came on and you were not the cause (like you took your seats out or something) I recommend you take it to the dealer as soon as you can.
Old Sep 8, 2011 | 09:16 PM
01tl4tl's Avatar
thats it- if you did any electrical work and then it came on--reset and see
if you did no work and it came on- there is a problem
no spills of soda or other fluids on seat or in car?
10year/150kmiles srs special extended warranty
call dealer for appt, and dont require the airbags~
SRS light ON= airbags turned OFF
Old Sep 8, 2011 | 09:18 PM
01tl4tl's Avatar
dealer can run your VIN and tell if covered, or look in our list in the diy section
or call acura care 1 800 382 2238x5 ask if any OPEN recalls.. and extended warranties
ie: trans, seatbelts, srs
Old Sep 8, 2011 | 10:03 PM
03TLKEV's Avatar
No I'm pretty sure nothing was spilled and I did no electrical work. I ran my VIN on the website and all it said was the trans recall was "repaired" and the new airbag recall is still open. Did not say anything about warranty ext's. Are they not shown there? Would it be worth resetting? I used to work at a VW dealer (I know way different vehicles) and low voltage would set off weird things like airbag lights. If I reset the system and the light stays off would that mean the airbags may still not be functional or only if it went back on?
Old Sep 9, 2011 | 09:18 AM
01tl4tl's Avatar
Do you have low voltage? tested battery and alt condition? parts stores do it for free
the website does not show the extended warranties.
have to call the 800 and have them look it up in the special warranty book
Trans recall `fixed` only means oil jet kit was installed,,but it wont show if entire trans was replaced later!
Airbag inflator recall OPEN means get your car in there quick! its not fixed yet!!
something about the speed of deployment being too high, they swap a part- not the bag
there is a problem with a few of the SRS parts-sensors,
Per service managers on here: there is 99.9% chance its covered by the warranty
1 part out of 6 not covered but that 1 is a rare failure
there is a reason the warranty got extended so far,,,probably not by acuras choice~
call and make appt, or go see the service manager and ask when they want it-
versus the phone girl who only cares about filling the spots in the book,
not about which tech does these jobs and is available.
Some days are better than others
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
