SRS light?
Old Nov 26, 2005 | 01:19 AM
Rav
SRS light?
Hey,
I have a 2000 TL and the SRS light came on. I took it to the acura dealership and they said i need a new battery? Will changing the battery fix the problem? Also, the dealership changed the SRS computer thing a few months ago as well.
Old Nov 26, 2005 | 06:11 PM
fsttyms1's Avatar
It may fix it but if the light is still on your going to have to reset teh light yourself or have acura do its
Old Nov 27, 2005 | 04:34 PM
HoFF's Avatar
4th Gear
Check out this thread:
https://acurazine.com/forums/showthr...ighlight=light
This method worked for me. Note: you could also make your own "SCS service connector" with a paper clip. That's what I used.
Here is the proceedure
1. Turn off ignition
2. Connect the SCS service connector to the 2pin wire you take out of the drivers fuse box and is now hanging from a thicker harness.
3. Turn on ignition
4. SRS light comes on for 6 sec and then goes off. Before it has been off 4 sec, Remove the SCS connector.
5.SRS light turns on again. Reconnect the SCS service connector withen 4 sec of light coming on
6. Light goes off, remove connector witeh 4 sec after light went off.
7. SRS light blibks 2 times telling you the memory is erased.
8. Turn ignition off.
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
