squeaking in rear
Old Jul 21, 2008 | 06:58 PM
achen0122's Avatar
Question squeaking in rear
there is a squeaking noise when i go over bumps that comes out of the rear passenger well. my car has been lowered on H&R sports and tokico blues.. any ideas?
Old Jul 21, 2008 | 07:01 PM
ts_vaj's Avatar
Same here too...but I heard the squeaking even before I lowered my car....could it just be the seats?
Old Jul 21, 2008 | 07:10 PM
achen0122's Avatar
i dont think so.. i don't hear it when im inside.. only outside. im not car savvy but could it be some kind of joint? when i had my car lowered, they replaced the suspension mounts as well just fyi
Old Jul 21, 2008 | 08:39 PM
achen0122's Avatar
bump... anyone??
Old Jul 21, 2008 | 08:44 PM
djescobar973's Avatar
Keep it flush!
end links maybe? I had somewhat of a same issue after my coilover install.. this week I was getting some work done and noticed the link was broken. we replaced it and the issue is gone.. get underneath it. maybe lubricate some areas...
Old Jul 21, 2008 | 08:47 PM
achen0122's Avatar
sorry.. im not sure what endlinks are and what they look like.. for something like this i will prob take it to my local shop.. if they have to be replaced what $ should i be prepared to pay?
Old Jul 21, 2008 | 11:54 PM
importvizion's Avatar
02 WDP type-S Navi
endlinks are the tiny rods that connect your sway bars to your suspension. looks like this, I circled the endlink for you. Expect to pay 250-300 at the dealership, a regular mechanic would probably charge you 200 or less. It can also be your bushings going bad, or ball joint so really your best bet is to have your trusty mechanic test it out for you if you're not too mechanically enclined.
Old Jul 22, 2008 | 12:09 AM
nguyen's Avatar
on my car i lifted up the rear n found that the black boot or pillow mount looking thing that is on top of the spring was broken and that caused the sqeaking
Old Jul 22, 2008 | 05:49 PM
hondaman4life's Avatar
5th Gear
I"ve never heard them been called ENDLINKS-i have been noticing that term a lot on this site....must be an american thing. In Canada we call them Sway bar links. is that not used over there guys??
Old Jul 22, 2008 | 06:59 PM
01tl4tl's Avatar
sway bar end links is the correct term- we are lazy and...
Moog makes beefy replacements for cheap- the rears seem to break especially during shock installation
Old Jul 23, 2008 | 05:47 PM
5th Gear
I just put the moog's on last week. they are greasable too, which is better than the non-greasable ones. (As long as you grease them regularily). and yes, they are priced reasonable. and ya-pretty much all sway bar links never come off without breaking, or torching them off. This is why engineers should try picking up a wrench once in a while.
kmawani
Feb 8, 2023 05:09 AM
2012wagon
Sep 29, 2015 04:21 PM
njresendez
Sep 21, 2015 11:23 AM
forrie
Sep 15, 2015 09:57 AM
jliu6789
Sep 8, 2015 08:02 PM
