Squeakin front seat
Originally Posted by 03TL_S
mine does it when i move around, and i've heard it in a few others, dealer says i need to condition the leather, but i disagree
Its not the leather. Its caused by a metal washer pressing against a nylon spacer in the seat buckle bolt. To fix: remove the seat, take a socket and remove the bolt that attaches the seat buckle to the seat, remove the thin metal washer that you will see stacked on the bolt close to the bolt head (the washer has a curved shape to it sort of like a potato chip), then put the bolt back on and you are all set. As far as I could tell the metal washer is designed to press against the nylon washer that fits through the hole in seat belt buckle bracket. Presumably this helps hold the buckle upright when its not attached the the seat belt. However removing it does not cause the buckle to drop down between the seat and console as there are two nibs on the buckle bracket that only allow the buckle bracket to move up or down by about 2 inches. Also, there is still plenty of tension on the nylon washer when the metal washer is removed. I did this fix on both my driver and passenger seat belts about 3 years and 70k miles ago and the squeak has not returned. Some have just sprayed WD40 down between the washer and I tried this too before finally taking the bolt off to see what was really going on, but at least for me the WD40 was only a short term solution and the noise had come back a few months later. It shouldnt take you more than about 1/2 hour to fix it the right way as I described above. I didnt take photos when I fixed mine but once you take the bolt apart you will see exactly how the washer's location creates the much-dreaded sound.
Good luck.
Good luck.
Good luck.
Good luck.
Originally Posted by Shaqs2002TLS
Adjust your seat.... Lift it up from the back side and the sound goes away. You'll get used to ur new seating position. Just lift it about 2 inches OR until it goes away.
I'm doing the same thing and it works.
is it hard to remove the seats? is it just 4 bolts? any heated seats wires and etc?
i have squeeks passenger and driver... even when i move the seat all the way back (leaning back) it makes a grinding kind of sound.
The seat comes right up when you undo the bolts. Then there is a plug or two that you'd have to disconnect as well. Note that you dont have to remove the seat from the car altogether to work on it. The only reason to take it off the floor is because its too hard to get to the seat belt buckle with the seat in place. When you undo the 4 seat bolts, you can just tip the seat on its side a little to get to the 2 screws that hold the plastic cover to the side of the seat, and then to the seat belt buckle bolt. I'd recommend you do it in the car so you avoid the risk of scratching the plastic door sill or worse while trying to take the seat out. The metal brackets under seat can easily damage stuff on the way in or out of the car even if you are trying to be careful with it.
The driver seat squeak could also be related to the sliding center console cover and the lever for the lumbar support in the driver seat. When the console cover is all the way back it rubs against the lumbar lever and there is a constant annoying squeak. Sliding the cover forward gets rid of the squeak.
Originally Posted by fsttyms1
then there is something wrong with your seat or center console. because they arent supposed to touch. mine has never come close to touching
rockyboy
Aug 4, 2024 10:35 AM
