squeak while turning
Old Jan 19, 2005 | 09:48 AM
Team Nighthawk Member
ive just heard squeaking from the front of my car from both sides while turning can someone please tell me what this is from and how to fix. i checked the power steering fluid and its full.
Old Jan 19, 2005 | 09:53 AM
mackntheacc's Avatar
my girly girl
same shit as me i had
the wheel ball is not lubricated enough
i had to buy a new ball from acura cause i kept greasing it myself but it alays came back .
or
you can take the wheel off and try and clean it i heard of?
many people had this problem but its a easy fix but annoying as hell.
if you drive on it too long the bolt can crack and you can lose control of your car.
so get it fixed soon and try not to drive on it too much especially on the highways.
Old Jan 19, 2005 | 09:56 AM
so after i take off my wheel where would i lube
Old Jan 19, 2005 | 10:04 AM
my girly girl
you cant get inside to the actual bolt joint.... thats why i had to roder a new one and they installed it.
i guess you can just use wd 40 for now and turn the wheel all the way to the left and lube the joints and turn all the way to the righ and lube the joints(thast if you dont take off the wheel) if you take off the wheel which i did not i assume you just clean everything then lube it .
once again i had to replace the whole joint so their for i am not sure bout where you would lube it when you take off the wheel
Old Jan 19, 2005 | 10:06 AM
aprox how much it cost when u bought a new one
Old Jan 19, 2005 | 10:10 AM
Lucky37's Avatar
Take off front wheel, undo the center bolt and pull off the rotor. then proceed to pull the whole drive shaft out making sure not to damage the seal where it goes back into the transmission. once thats off, you can take the rubber boot off by breaking the metal ring used to lock it. then buy the rubber boot, like 5 or 6 bucks and also a thing from pepboys, i forget what its called but its for clamping the metal lock, its a clamping tool. before fitting the rubber boot back on, put in some ball joint grease, pepboys too, and then put everything back together. you can even change the seal if you like, its like and extra 20-30 bucks. the ball joing container tells you how much to put in, in fact it usually comes in small packets that you just open and dump the whole thing.
Old Jan 19, 2005 | 10:12 AM
thanks, is this a hard process or should i get someone who knw what there doing to do this
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
njresendez
Sep 21, 2015 11:23 AM
