Springs without the Camber?
Old May 8, 2001 | 01:33 PM
jumpman's Avatar
Post Springs without the Camber?
Just got a used '99 TL... want to get rid of some of the gap in the wells w/ lowering springs, but don't want to deal w/ the camber it might cause... Can anyone suggest a brand/model of lowering springs that will lower the car, even just a little, without affecting the camber? Thanks!
Old May 8, 2001 | 01:35 PM
Acura3200's Avatar
Post
Comptech
The drop is under 2". Click on the pic in my sig for pics of my car with the Comptech drop.
you don't need a camber adjustment with Comptech springs.
<A HREF="http://www.adamoski.com/acura.html" TARGET=_blank> </A>
Old May 8, 2001 | 09:40 PM
Jens
Guest
Posts: n/a
Post
But definitely do an aligment as the toe goes way out on the front end.Jens
Old May 8, 2001 | 10:45 PM
Shoofin's Avatar
Post
But you don't need to put the camber kit on the car.. An alignment is always recommended when you modify your suspension in any way..
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech Springs and Sways, CL Type S wheels wrapped with 225/45/17 Dunlop SP9000's, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, Gutter Guard Grille, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Old May 23, 2001 | 04:21 PM
veloce's Avatar
Unhappy
I got my Comptech springs put on last week and took it in to get aligned by a pro body shop today. they called me up earlier and *****ed me out. said my car was out of alignment and the camber on both front and rear is way off and there is no way to put the camber in specs. what the hell is that? should i get a second opinion on the alignment or should i just get a camber kit? who out there has a camber kit?? pls help......
Ed
Old May 23, 2001 | 04:42 PM
Smile
H&R o.e springs will drop your car slightly to close that ugly fender gap.
Comptech Exhaust
Comptech Filter
Piaa 1700x
Old May 23, 2001 | 05:17 PM
SL1200MK4's Avatar
Post
Your camber will go off with any spring or coilover. It's just a matter of how much. I think you will be okay with both Comptech or H&R. If it really bugs you then get the camber kit...
Old May 23, 2001 | 06:46 PM
jumpman's Avatar
Exclamation
Does anyone else have a bad camber/alignment experience they would like to share, and the solution that came about??? I simply want to get rid of SOME of the Madonna-like gaps in my fenders, without having to worry about camber kits and grossly uneven tire wear... it seems most everyone doesn't have this problem, but i'm sure it's out there... please speak up ppl... Thanks!!!
Old May 23, 2001 | 07:26 PM
Acura3200's Avatar
Post
I can assure you that everyone here with Comptech springs will not have camber problems. If you're looking for people with mild drops, +/- 2 inches, that have problems, you may be looking for a while.
Comptech springs will not give you camber problems.
Old May 23, 2001 | 08:49 PM
adamyankee's Avatar
Post
Trust us, you don't need a camber kit with a drop less than 2 inches, but check your tire wear periodically just to stay on top if any problems should arise.
Under Body Kit/Rear Wing Spoiler/26 Piece Wood Grain Console/BurlWood Shift Knob/30% Smoke Tint/Comptech Sways & Springs/02 Tails/Altstadt I's on order/Clear AEM CAI on the way!!
More Pics
Moderator Acura-TL.com Tires/Wheels Forum
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by adamyankee on May 23, 2001 @ ]</font>
Old May 23, 2001 | 10:38 PM
Don's TL's Avatar
Post
My car is dropped more than 2 inches on Ground Control and I don't need a camber kit. The alignment guy said my camber is only off 1 degree or something and is perfect for a lowered car and don't need no kits, nothing!
Old May 23, 2001 | 10:42 PM
BlackTL2K's Avatar
Post
I have Comptechs as well. You should not need a camber kit as long as the springs are install correctly.
My left rear was slightly off (like .5 or less); my tire treads are wearing evenly and I have had no problems.
Old May 24, 2001 | 12:09 AM
TLBaller's Avatar
Post
Hey DON'S TL.. you got ground control on your tl huh? which year is your car? i want ground control for my car but i have the 1st generation TL. Do you know if they have it for the 1st generation? oh and 1 more thing... do you have to jack up your car in order to lower your ride height??
Old May 24, 2001 | 12:43 AM
Don's TL's Avatar
Post
TLBaller: I have a 2000, I'm pretty sure they have an application for the 1st gen, check them out at www.groundcontrol.com. I have to jack up the car to adjust the height, but it's not hard at all! hope this helps.
Old May 24, 2001 | 08:43 AM
veloce's Avatar
Angry
i heard you guys say over and over again.. dont need a camber kit with Comptech springs.
i got my car back from the alignment shop. it pulls like a biatch to the right. the camber is off on the rear, both left and right. the tech told me there is no further adjustment possible without adding a camber kit. i will scan the spec. sheet and post it in a bit.
Old May 24, 2001 | 08:53 AM
Acura3200's Avatar
Post
Originally posted by veloce:
I don't understand, first you were looking for springs and now you have them?
If you have springs, it definitely sounds like something was not done righton the install. After my springs were installed there was absolutely no change in the pull and the camber difference is barely noticable unless you REALLY look close.
I now have a problem with the car pulling to the right, but it's a problem with my new tires. Did you do anything with your tires? Even rotating them, if there is uneven wear, will cause the car to pull.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Acura3200 on May 24, 2001 @ ]</font>
Old May 24, 2001 | 10:06 AM
veloce's Avatar
Post
"I got my Comptech springs put on last week and took it in to get aligned by a pro body shop today."
pls check new post: http://www.acura-tl.com/ubb/Forum1/HTML/008082.html
Old May 24, 2001 | 10:38 AM
sneuxstorm's Avatar
Post
you could have a toe problem rather than a camber problem. It could be the tires. Or it could be camber. The alignment shop should be able to fix it. It may seem strange, but there really is a right and wrong way to install springs. I have no idea either way. I had mine installed by a buddy that does it for kicks. My GS-R dropped nearly 3 inches, sent it to the alignment shop and it came back with proper toe, and a slight negative camber. I still manange to get 50k miles out of the stock tires before switching to Toyo Proxis'. These lasted another 40K. I have 110K on the car now, and the tires look great...but the springs are sagging and it droped another .5 inch. My cousin on the other hand took his civic to one of "those" shops, had the same brand and model of springs installed, and his came back with so much negative camber that he got less than 10k miles on the car before the tread delaminated and seperated from the rest of the casing.
All I can say, is that you should take it to a good alignment shop, if they can't get it close to spec (close...cuz it will never be perfect) such that it it no longer pulls in either direction, you should take it back to the shop that dropped your car and have them re-install them.
just my 0.02
Photoshop Chop Shop
Inspire32V's Avatar
Post
Veloce,
You've got an unusual case of camber trouble with the comptech springs. Comptech does have camber correction kits available and there are a few available on autocarparts.com
I have a 99 with comptech springs without camber kit.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
