sport shifter
Old Jun 26, 2012 | 10:59 AM
kuckle1's Avatar
sport shifter
I don't use it much but when I have it doesn't let me shift to 2nd manually it will do it by itself but the rest of the gears work, and when down shifting it won't let me shift to 1st manually it does it by itself, how do I fix that? Oh and D5 doesn't light up anymore.
Old Jun 26, 2012 | 11:58 AM
fsttyms1's Avatar
Nothing u can do about it. It's programmed into the ecu that way. No way to change it.
Old Jun 26, 2012 | 12:14 PM
webmastir's Avatar
2003 TL
& d5 light: https://acurazine.com/forums/showthr...ighlight=light
Old Jun 26, 2012 | 12:32 PM
kuckle1's Avatar
So they're all like that ?
Old Jun 26, 2012 | 01:11 PM
zmwang's Avatar
Read the manual first.
Old Jun 26, 2012 | 03:37 PM
Skirmich's Avatar
Read your Manual Bud!
SS will auto Shift into 2nd to Save some Gas and Protect the Engine otherwise you will be reeving 1st alot getting horrible City MPGs...
Only Way to Control it is to Carefully Press Gas 1/2 to make 1st last longer... IMO: You will look Silly Reeving 1st every Stop.
Old Jun 26, 2012 | 05:46 PM
JDTL-S2002's Avatar
it will stay in first longer if you got WOT but other than that it will shift into 2nd around 2800 rpms and the only way to manually shift all gears is to start in D1 and go up through gate shifting...
Old Jun 26, 2012 | 07:14 PM
Karanx7's Avatar
Unregistered Member
It auto shifts 1-2 in case your mom accidentally shifts into SS at a red light. It's a family vehicle after all.
Old Jun 26, 2012 | 07:15 PM
Karanx7's Avatar
Unregistered Member
Originally Posted by webmastir
Useless thread. Search and you can find my DIY for changing the D5 bulb.
Old Jun 26, 2012 | 07:23 PM
Skirmich's Avatar
FYI: You dont have to WOT to Make 1st Last Longer
Anything Beyond 1/2 Gas will.... WOT will make it Redline.
Old Jun 26, 2012 | 08:13 PM
01tl4tl's Avatar
please download an owner manual free at www.owners.acura.com
it explains the speed/rpm limits for each gear
Use of SS is likely to cause excess heat in the weak part of our trans
Leave it alone!
neuronbob
23
Jul 16, 2019 10:48 AM
Jul 16, 2017 07:33 AM
MikeJM310
Sep 24, 2015 07:24 PM
