speaker Help Please
Tl fever...cureless!
1 Post
speaker Help Please
Hi, i need some halp in speaker size ....i am little confused...speaker size for 99 tl stock is 61/2 all around? i am getting infinity Kaapas tomorrow..Do i need all 4 61/2 and do they have to be components or just full range coax is fine? please post reply ASAP...i tryed the audio section no help there..not sure if i need components or coax does it matter? Really appriciate your help
God bless
God bless
Either or works, if you get components, you'll have to do some modifying and mount them. I'm looking at co-axles right now, and one thing I've found out about speakers, watch the mounting depth, the TL's bose speakers are pretty shallow. I'm sticking around a 2" mounting depth max just to be safe.
I would get a set of components for the front and coax for the rear
Kilos of yayo in
With component speakers the tweeter is separate from the midrange speaker. With coaxials the tweeter is mounted to the midrange speaker so its all self contained. Just be aware if you get component speakers you are going to have to mount them. If you don't want to modify and or cut up the car just get some decent coax speakers.
kappa's are a pretty deep speaker. the worst you would have to do is cut the back of the plastic where the speaker is mounted, or just take it out and use an after market spacer. like the other guys said, mounting the tweeter and the crossover is your other complication. i went with alpine coax all around, and im more than happy with it.. if i might throw the idea out, is to dynamat that biotch up. youll see a huge increase in overall sound, little pricey but more than worth it.
what alpine speakers did you went with? i just bought some type-s and wondering if the fitmeant was fine and did you use any spacers? thanks
yeah type s here also. they will barely fit, youll have to secure them into the factory spacer or after market. damn good speakers for the money. they're good with or without an amp, just make sure you use speaker harness's or get the polarity correct.
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
