Spark plugs pics
Old Oct 17, 2008 | 06:49 PM
1st timer's Avatar
UB6IB9
Spark plugs pics
These are NGK Iridium ,used them for abou 15k miles.
Notice one of them is all black while the others seem fine,why is that?
Old Oct 17, 2008 | 07:57 PM
bowlgers's Avatar
268hp 301tq @7.8psi
maybe a bad coil or it wasnt snug looks like blow by
Old Oct 17, 2008 | 08:11 PM
Gfaze's Avatar
S E L L
It looks like you might've had oil seeping through the spark plug tube seal in that cylinder. That crud is dried up motor oil. Did your spark plug socket have oil on it when you took that particular plug out? The only thing you can do is replace the seal, which means removing the valve cover so you might as well get the whole valve cover gasket set and replace everything.
Old Oct 17, 2008 | 09:09 PM
acutee's Avatar
That is what he said, bad seal. Normally, it is #1 plug. As you can see, other plugs are showing oil on them too, replace the seals for those as well.
Old Oct 17, 2008 | 11:43 PM
1st timer's Avatar
UB6IB9
do Bosch platinums need to be gapped?
Old Oct 18, 2008 | 08:22 AM
1st timer's Avatar
UB6IB9
[QUOTE=Gfaze;10099622]It looks like you might've had oil seeping through the spark plug tube seal in that cylinder. That crud is dried up motor oil. Did your spark plug socket have oil on it when you took that particular plug out? The only thing you can do is replace the seal, which means removing the valve cover so you might as well get the whole valve cover gasket set and replace everything. [/QUOT
I didn't have to force at all to unscrew the plugs,maybe they were not tight enough to begin with,that's why they look like that.
Old Oct 18, 2008 | 10:59 AM
fsttyms1's Avatar
Check the oil seal on the valve cover, Look in the hole and see if oil is leaking into it. Mae sure they are torqued properly. That looks overheated. You may be having a miss fire as well. I dont recommend using bosch in the TL.
Old Oct 18, 2008 | 05:43 PM
1st timer's Avatar
UB6IB9
Why not?
Old Oct 18, 2008 | 08:06 PM
Rajca's Avatar
wham bam thank you ma'am
ngk iridium ix are recommended for our cars, also check the gap on all plugs, just to make sure that its to correct gap. u dont know if the plugs were dropped, throw, stepped on.
Old Oct 19, 2008 | 09:19 AM
fsttyms1's Avatar
Originally Posted by 1st timer
Why not?
Do a search, because others have had issues with them not lasting as long, rougher idle, worse mileage.
Old Oct 19, 2008 | 11:00 AM
1st timer's Avatar
UB6IB9
My argument is that a spark is a spark,that being said,I don't see a reason to spend more money on spark plugs.
Old Oct 19, 2008 | 11:01 AM
1st timer's Avatar
UB6IB9
What should the gap be?
Old Oct 19, 2008 | 11:23 AM
ArTL-S's Avatar
I have dead hookers in
You are right a spark is a spark is a spark......but if you do a search you will read and learn that other have tried spark plugs other than NGKs and not had good results. So although a spark is a spark some sparks do not work as well with our cars as other sparks do
Old Oct 19, 2008 | 11:24 AM
Rajca's Avatar
spark plug gap.0.04in (1.1mm) for both the tl-s and the tl-p
TL-P: ngk-PZFR5F-11
TL-S: ngk-PZFR6E-11
Old Oct 19, 2008 | 11:55 AM
9932's Avatar
2G wanting 3G
come on that statement is like people putting reg gas instead of premium. like the extra 5 bucks is gonna kill you
Old Oct 19, 2008 | 12:03 PM
1st timer's Avatar
UB6IB9
Why spend it if you get nothing out of it?
Old Oct 19, 2008 | 12:11 PM
Rajca's Avatar
higher compression need higher octane. its what our cars are tuned for. your not going to feel any difference in teh beginning, its the long run that counts.
Old Oct 19, 2008 | 07:17 PM
fsttyms1's Avatar
Not all spark plugs are created equal. Not all spark plugs produce the same type of spark. Get the ones that are known to work and recommended for our cars.
Why lose something by not getting what your supposed to.
Old Oct 21, 2008 | 12:31 AM
Tim67580's Avatar
Newb
Might as well go with NGK, reasonably priced, and honda OEM manufacturer.
Old Oct 21, 2008 | 12:37 AM
Tim67580's Avatar
Newb
Also....
I wouldn't believe it if I hadn't heard so many stories, but I have heard numerous occasions in which Bosch plugs cause Honda/Acura's to run poorly.
As for your first plug I would be willing to bet money its the oil/valvecover seal leaking slightly. Also the gaps look a little large to me, but its hard to tell online.
Old Oct 21, 2008 | 09:02 AM
1st timer's Avatar
UB6IB9
Originally Posted by Tim67580
Also....
The fist plug was very loose,not torqued at all and the gap is .0470",I think .007"bigger than it should be.
Old Oct 21, 2008 | 11:14 AM
01tl4tl's Avatar
when you buy the new NGK Iridium IX plugs for your baby- 7 bucks each- you will discover they have a super fine wire for that side electrode- and you are not able to gap them with a regular round plug gapper tool
Just buy the correct parts
ziners tried bosch- didnt last, and car ran badly soon after install
they had to do the work all over again,
and personally-- I dont like repeating that particular leaning over the engine job!
Acura approved is plug is ngk or Denso-, denso cost more and last less miles if you prefer
dealer will sell you ngk for 25 bucks each! go to local parts store like kragen for 7
Old Oct 21, 2008 | 11:15 AM
01tl4tl's Avatar
plug torque is critical- use a torque wrench if you cant set them by hand per the directions.
Use a small amount of plug anti sieze on the threads too
Old Oct 21, 2008 | 11:19 AM
01tl4tl's Avatar
I would seafoam that engine twice and have the codes checked- may be a real problem like TB is not adjusting correctly- for all of them to look off
light tan is normal
excess gap is often plug wearing down of the center electrode
they design these plugs so everything sits square for max firing
if you want tech details ask IHateCars- he indexes- points the open end of the plug towards the intake valves!!- just like on his real drag race car
Old Oct 21, 2008 | 03:32 PM
TOTAL~LUSH's Avatar
acura spent allot of money enginering and designing these cars a certain way. if they wanted you to use all different kinds of spark then they would have designed it that way. in the owners manual they give you two options. i am sure acura tried different spark plugs and the options they give you are for the best results.
Old Oct 21, 2008 | 04:43 PM
1st timer's Avatar
UB6IB9
Can I just regap the plugs to 0.040 and reuse them as they only have about 10k miles on them instead of buying new ones that run 17 cnd dollars for a pair.
Old Oct 21, 2008 | 06:20 PM
01tl4tl's Avatar
buy 6 new plugs and 2 cans of seafoam
Old Oct 21, 2008 | 09:15 PM
1st timer's Avatar
UB6IB9
What codes? Car is not throwing codes!! I just seafoamed a month ago.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
