spark plug
Old Sep 16, 2004 | 12:10 AM
69tl's Avatar
spark plug
i was wondering what kind of spark plug do you guy use when changing out the old one. right i'm thiking of getting the NGK Platinum $11 each....what do you guy think
any input or comment would be preciated.
thanx in advance
Old Sep 17, 2004 | 07:50 PM
subtledreamer's Avatar
woooo!!
i dont know anything about spark plugs
but i do know you can do a search
http://acura-tl.com/forums/search.php?searchid=117249
see if there are any threads that helps, good luck.
Old Sep 17, 2004 | 08:13 PM
yield2s's Avatar
go w/ Denso or NGK
Old Sep 18, 2004 | 11:16 AM
TeknoKing's Avatar
get NGK IX IRIDIUM spark plugs, the best plugs for performance and money that you can get.
Available at PepBoys,Ebay or the NGK website.
Old Sep 19, 2004 | 05:07 AM
69tl's Avatar
so is it best for me to use the IX iridium over Double Platinum on NGK??
thanx for all the help
Old Sep 19, 2004 | 12:09 PM
TeknoKing's Avatar
well Iridiums do last longer and do provide a better spark.
Old Oct 21, 2004 | 11:38 AM
99TLHeather's Avatar
Hey Teknoking, I have a '99 TLP with Header and intake. I have 59,000 miles and it's beginning to idle somewhat rough. I want to get the iridium IX. Should I get the ZFR5FIX-11 comparison to Denso IK 16 or should I go with the Denso IK 20 comparison...not sure what the item # is for this in the NGK Iridium IX. Planning on getting the UR crank pulley in the future.
Thanks in advance for your help!
Old Oct 21, 2004 | 11:47 AM
TeknoKing's Avatar
ZFR5FIX-11 thats what im using. I prefer NGK, its your choice.
Old Oct 21, 2004 | 12:06 PM
fla-tls's Avatar
On the way!
For a 99 TL-P you would get the IK16 equivalent plug. The IK20 is a colder heat range and is used on the Type S.
Old Oct 21, 2004 | 12:15 PM
Thanks for your quik responses fellows!! Therefore, the colder plugs (IK 20..TLS), are used for mods such as S/C..Turbocharged & NOS. Is it safe to say that any direct bolt on mods (h/i/e/p) for the TLP should stick with IK 16/equivalent plug?
Old Oct 21, 2004 | 12:30 PM
fla-tls's Avatar
On the way!
The general rule is to go one heat range colder for every additional 75 hp. On an TL-S, if you are supercharging or using NOS, I would go one heat range colder than the IK20 (IK24?).
On a TL-P with i/h/e/p you should probably stay with an IK16.
The easiest way to tell is to pull one of your plugs and look at the ceramic insulator. The color and condition of the insulator will tell you if the plugs are too cold or too hot. Too cold, and they won't heat up enought to be self-cleaning (the insulator will get dark from carbon). Too hot, and the insulator will be white - perhaps with small dark specs on it.
Here's a good site for reading up on this (link).
You can learn quite a bit from used plugs.
Old Feb 23, 2013 | 10:11 AM
spydercatt's Avatar
Here is a Do It Yourself video on how to change out the spark plugs on a j series engine on a Acura/Honda V6 engine. Hope it helps. I have aways used NGK and have been very happy with them.
Old Feb 23, 2013 | 02:43 PM
Skirmich's Avatar
Holy mother of thread revival badman!
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
