something wrong with driver side door lock. plz help
Old Sep 29, 2011 | 04:35 PM
99acuratldriver's Avatar
hello i have a problem with my driver side door lock. i have to use my key to unlock the driver side door, after that i am able to use my remote to unlock the other doors. When i use my remote to lock the doors all the doors lock except the drivers side; but if i press down on the driver side lock then all the other doors lock. any suggestions would be helpful, thank you.
Old Sep 29, 2011 | 05:05 PM
GarethQ's Avatar
5th Gear
Sounds like something that is intermittently to my 99TL the last couple of weeks. Dealer says need new actuator. Holding off since dealer is asking $200+.
Old Sep 29, 2011 | 05:06 PM
GarethQ's Avatar
5th Gear
Oops! Meant to say "intermittently happening" to my 99TL.
Old Sep 29, 2011 | 07:24 PM
luder917's Avatar
SSM FTW
same thing happen to my TSX. first it was intermediate. then one day it just stopped working. $200? damn. find someone on here local to you, im sure someone here can do it for way cheaper.
Old Sep 30, 2011 | 11:05 AM
fsttyms1's Avatar
Do you notice any extra effort in locking it with the key or when pushing down on the lock post?
Old Sep 30, 2011 | 01:10 PM
alexh1266's Avatar
That happened to my passenger door.
Needed extra force to push it down to keep it locked.
When I would unlock the doors the passenger door would sound like a springy sound really loud. Then after a while it just wouldn't lock anymore with the key fob or pushing down.
Had the actuator replaced and fixed the problem
Guess its a common wear and tear item with age.
Old Sep 30, 2011 | 02:19 PM
fsttyms1's Avatar
A lot of times its the lock itself. It gets rusty and stops moving. Happened to me. Had to take the lock mechanism out and soak it in penetrating oil and work it. Came loose and every thing works great. Seen a bunch of members have had the same issue.
Old Oct 26, 2011 | 03:48 PM
Thanks for ur replies, the driver side doesn't need extra force to lock, but sometimes the key fob works and at times it doesn't. I'm not looking to spend 200+ on an actuator.
Old Oct 26, 2011 | 07:02 PM
MrKev's Avatar
Yea the door lock actuator is pretty common in a few acuras, the part is fairly cheap around $30 I think. If you have a 10mm + ratchet, couple screwdrivers and a clip remover, you can get the job done
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
govtcheez
Oct 1, 2015 12:21 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
