Small shudder when accelerating
Old Feb 7, 2012 | 02:01 PM
longlivethetl's Avatar
3rd Gear
Hey guys,
Love this forum...first time i couldn't find a solution for a problem im having.
My 2002 tl has 190k with original transmission. Since 150k, when accelerating, randomly, a small shudder will occur when shifting from second into third. I find it hard to believe that my transmission is finally going because this shudder is exactly the same as it was 40k miles ago. The shudder does not occur every time...just randomly. Any suggestions?
Old Feb 7, 2012 | 02:18 PM
3rd Gear
Forgot to add something...tach jumps 250 rpm's while driving...can only see the change on the tach...cant feel any actual change
Old Feb 7, 2012 | 02:24 PM
Type-ES's Avatar
When was last fluid change?
Old Feb 7, 2012 | 02:27 PM
Karanx7's Avatar
Unregistered Member
It's the transmission. Just think about it this way: what else could it be? I've yet to heat about a shudder caused by our engines, and if it happens only when shifting...
The shudder doesn't necessarily mean that the tranny is going to die soon. It may have a lot of life left. Still, you got your miles out of that OG tranny. 190k jeez..
Old Feb 7, 2012 | 02:28 PM
Karanx7's Avatar
Unregistered Member
I had a similar shudder. Changing the fluid fixed it.
If you have never changed your fluid in those 190k, DON'T DO IT!
Old Feb 7, 2012 | 02:43 PM
Type-ES's Avatar
You can do one drain and fill ever couple thousand miles. Slowly add some new in.
Old Feb 7, 2012 | 03:12 PM
3rd Gear
Ok...figured i should NOT change the fluid because it never has been changed! Thanks karanx7 for clearing that up! Guess i should just live with the shudder and praise the tl gods for giving me such a trooper of a tranny!
Any thoughts on the tach jumping 250 rpm with no noticeable change in car?
Old Feb 7, 2012 | 05:09 PM
01tl4tl's Avatar
you can clean the pressure switches/shift selenoids without changing fluid
and replace the external filter if your year is so equipped
Old Feb 7, 2012 | 08:42 PM
jpadilla's Avatar
curious as to why not ...
Old Feb 7, 2012 | 09:06 PM
Karanx7's Avatar
Unregistered Member
After 190k of running without fluid change, there is going to be sludge buildup. Changing the fluid can disturb the setup going on, and will most likely kill the transmission within a few thousand miles.
The sludge actually becomes an necessary part of the transmission.
Normally, you shouldn't touch the fluid if it has been over 100k. Since he is at 190k, he's almost guaranteed to kill the tranny with a fluid change.
Old Feb 8, 2012 | 04:03 AM
Sperry's Avatar
2000 TL Black on Beige
Front engine mount ???
Is the "shudder" coming through the fuel pedal?
Old Feb 8, 2012 | 10:03 PM
RC99TL's Avatar
Nice!
Swap out existing fluid with a 3x3 using Dw-1. Bet the shudder goes away.
Replace the 2nd and 3rd pressure switches(easier than changing your oil) and hopefully you become the exception to the rule.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
27trains
Sep 30, 2015 09:44 AM
