Slight Pull to the right
I just purchased some new tires (Falken Ziex Ze512's) had them installed and balanced, (found out I have 2 bent rims... Thank you NYC potholes :rocketwho ). I alos got a 4 wheel alignment. After the alignment my car still pulls slightly to the right, at low speeds 20-45 MPH. The guy at the dealer told me that it could be a bent Upper oa Lower control arm. I don't know what the hell it could be.... Anyone here have any ideas.. suggestions
hey
my 01 tl was pulling to the right and people tell me that its my rotors cuz i got an alignment done once i bought the car and its still pulling but another thing is that when i brake my steering wheel shakes and i think its more likely the rotors... hope that help ya
Originally Posted by TLProspect
What about a Front End alignment?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
swap the two front tires if you have multi-directional tires.
Originally Posted by TLKrazey20
I have the Falken Ziex ZE512's how do I tell if their multi-directional?
you could also check tirerack.com. im not 100% sure but they should have that info.
Type II Coupe
Originally Posted by Pure Adrenaline
Hmm, my car pulls to the left. Then when I straighten out the steering wheel, it pulls to the right. I think it's just the nature of our cars, kind of like how the rear driver's side suspension sits about a quarter-inch lower than the rear passenger side.
Mine doesn't...
mine pulls to the left, and i have had multiple alignments trying to get rid of it, i tried different tires, still did it. it could be acouple things. the output on the tranny is harder on one side than the other causing it to pull (per dealer, and a independent alignment shop), the engine insnt sitting perfectly in the engine bay, and brakes. those arethe options i have been told by multiple places.
Originally Posted by AcuraTLS03
have u tried swapping the two front tires? putting the left one on the right and vice-versa?
Mine pulls to the left and i was told by 2 places that the rear left camber was the cause and I needed a camber kit. My car is all original and has not been lowered
emailnatec
29
09-28-2018 04:27 PM
