Side effects of lowering a car?
Happy with my STi!
Besides messing up the alignment and scratching the body kits, what are other side effects from lowering a car? If you have lowered your car, how did you lowered it (what products did you use) and what are some of the problems you have encountered (if any)?
im lowered on comptecs....i have cracks in my paint on my bumper where it meets the front fender near each wheel well....also i have some paint chips on the top of my bodykit where it meets the bumper....probably from hitting driveways....
TL-S driver
I have TEIN SS's. Besides scratching the body kit, I had a little rubbing issue with the aftermarket wheels/tires. That was taken care of with a little dremel.
Life goes on.
Springs used: Comptech
side effects: No more 4 x 4 factory look and better handling.
Problems: Creeking noise from driver front wheel well which was resolved by spraying some Tri-flow.
the only real side effect should be less clearance
side effects = chance of your wheels looking like ... / \ .... leading to purchasing a camber kit
at least that's what happened to me. I just got my camber kit installed this weekend and my car is back to factory specs. i'm happy again.
Cons
.. you're limited to where you can take your car.
.. going up a steep slope is no problem but coming down it is.
.. your bound to bottom-out sometime.
.. your Apex'i WS exhaust hangs lower than other exhausts..so they might get scratched up a bit.
.. negative camber.
.. blown shocks.
Pros
.. better handling.
.. no more 4x4 look.
.. negative camber.
.. blown shocks.
Pros
.. better handling.
Happy with my STi!
Originally Posted by `ill*tl
Cons
.. negative camber.
.. blown shocks.
Pros
.. better handling.
.. negative camber.
.. blown shocks.
Pros
.. better handling.
i
Had an eibach prokit, my bro took em off and sold em, i jus ordered H&R sports today
Eibachs
- very aggressive look, loved it
- shreaded the under part of my bumper cuz there are some driveways u just cant escape (prokit lowers more than comptechs and H&R)
- other than the shreading of my bumper, no problems
i kno lowering will wear out ur shocks qucker
Eibachs
Originally Posted by thsiao
I wanna get the H&R OE Sport... would they also result in the same cons?
Like a mideget on a moped
i droped my car and i cant make u turns on streets anymore.. now most of them are 3 point turns... thats the worst for me... anyone know why that would happen?
I got H&R Sport Springs installed. 1.5 inch drop. It does everything better and feels like a GO Kart. Ride is softer and alot more fun. I am getting 18 inch RIMS installed very soon.
I wouldn't know why the car doesn't do U-Turns anymore. Mine turns better.
Boomer SOONER
I wouldnt think that lowering your ride some would do that at all....how much did you lower it?
Happy with my STi!
The OE's shouldn't affect your ride too much since it gives a subtle drop. Just be careful when driving down slopes..and watch hitting huge bumps as adding aftermartket springs on stock shocks will make your car a bit bouncy..which could cause even the OE's too bottom out.
Bottoming out means when the springs (aftermarket) has the maximum amount of pressure on them..which causes them to completely collapse together..causing your car to slam in a downard motion.
Happy with my STi!
Is this bad for the car? Is this a normal thing with aftermarket springs?
nanos
11-12-2015 08:41 PM
