shocks
Old Feb 17, 2004 | 09:44 PM
jungsup81's Avatar
shocks
I have Eibach Pro-Kits and stock shocks. How do I know when my shocks are done? I hear squeaking sounds from the back every time i go over a speed bump. Is it time for new shocks?
What happens if I keep driving on a bad shock? How much time do I have before getting new ones? Do I need to change them out immediately?
Thanks much.
Old Feb 17, 2004 | 09:50 PM
jungsup81's Avatar
koni shocks
I have Eibach prokits on my 02 tl-s. You know how prokits give u slightly bigger gap in the front compared to the rear? Would koni yellows drop the front an additional .5" to match the rear gap? And keep the rear at the same height?
Old Feb 17, 2004 | 10:00 PM
fsttyms1's Avatar
the shocks shouldnt lower the car that is left up the springs, unless there coilovers
Old Feb 18, 2004 | 06:22 AM
TLMugen's Avatar
I'd rather be driving:
The Konis have adjustable spring perches (1" of adjustment I think). You could probably fine tune your f/r ride heights using them.
Old Feb 18, 2004 | 07:23 AM
hemants's Avatar
1. Squeeking is not from the shocks, it's the bushings. Your installer should have put some polyurethane tape there. oh well, just an annoyance, I wouldn't worry.
2. Worn shocks will feel bouncy. ie. when you go over bumps your cheeks will jiggle a bit longer than normal.
Old Feb 18, 2004 | 02:03 PM
check the struct mount too, if your car make this noise at low speed, this could be it.
Old Feb 18, 2004 | 02:27 PM
jungsup81's Avatar
well, I've had the prokits on for about 50,000 miles now with no problems before.
Old Feb 18, 2004 | 03:18 PM
patrick's Avatar
Re: shocks
See link below on how to tell when your shocks need to be replaced:
http://www.tokicogasshocks.com/evaluating.html
IIDXholic
3G RLX (2013+)
23
Oct 19, 2015 09:40 PM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
4drviper
Sep 23, 2015 07:42 PM
