Shift Lock Help!!!!!!
Old Feb 13, 2005 | 07:35 PM
JAKE2000's Avatar
My auto trans is stuck in park--had to use release button to shift. I also have no brake lights...checked ALL fuses but none blown. Could it be one of the relays??? Any help would be great since its about 40 miles to the dealer. Long way to go without brake lights
Old Feb 13, 2005 | 08:05 PM
ACURATECH's Avatar
sounds like shift interlock issue. you gotta tell me what year it is thow. 99?
after you get it out of park can you turn the key to 0 position with shifter in neutral?
Old Feb 13, 2005 | 09:41 PM
JAKE2000's Avatar
It's a 2000--and no the key won't go into the "o" position while in neutral.
Old Feb 15, 2005 | 11:17 AM
JAKE2000's Avatar
Broken brake light switch caused the problem
Old Jul 18, 2005 | 02:46 PM
jeets262's Avatar
7th Gear
I am having the exact same problem
the brake lights are out and I need to use a screwdriver evertime I need to change gears from park to reverse or neutral...any help would be appreciated
thanks
PJ
Old Jul 18, 2005 | 03:19 PM
brakejob's Avatar
:brakejob:
thanks
PJ
brake light switch
Old Jul 18, 2005 | 03:26 PM
Pure Adrenaline's Avatar
Dragging knees in
Amazing how the techno-nannies are watching over us. Brake light switch out = basically can't drive the car unless you override the safety system.
But I guess it's a good thing.
Old Jul 19, 2005 | 12:52 AM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
i had this problem...i think it was the SRS fuse (passenger side in 03s) but you did say you checked all the fuses.
i also heard of the brake light prob, someone told me it was a sensor near the pedals..
goo dluck
Old Jul 19, 2005 | 10:51 PM
JAKE2000's Avatar
Back in Feb it was a brake switch that went out and caused the problem.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
