Seat doesnt go back far enough!
My seat seems to not go back far enough. Im only ~5'11" and i feel like the seat is to close. My leg is always tired because i have to bend it up so far and the brake pedel is closer then the gas. Does anyone else feel this way? Is there anyway to fix this? I am thinking about selling the car to get back some leg room.
I dunno I got this car when i got rid of my Chevy Z71 so i guess im just used to all that space.
look at the link i posted above
Yo, i'm 6'2, drive a 99. I had that problem once, how bout you slant your seat back a little to angle yourself. IF that still don't work for you, then yeah, sell that car!! But there shouldn't be a difference in space throughout the years. So hope it works.
Thats cool, but do i have to weld it? The only problem with this is the decreses leg room in the rear......
yea there is less leg room in the rear, but when you have passengers slide it forward. If you tilt the front of the seat up some you will have more. You shouldnt have any issues at your height.
Also what works is if you use the height adjustment on the seat and sit higher. I'm 5'7" so I need to sit at the maximum height, and I found like that, it makes me have to move the seat way closer forward just so I can reach the pedals. In effect, a higher seat requires a taller person to reach the pedals because there's a longer distance from the seat to the pedals.
? I didnt even know there was a button for that. Theres the forward/backward button and then the back parts that moves back and forth. How does it work? Pull up on the forward/backward button?
I'm 6' 5" and fit OK. Wish I had more headroom, but legroom is OK. If you've got long legs, you really need to put the seat all the way down, then tilt the front up. This will support your legs so you'll be much more comfortable.
Since i found the up/down feature it has gotten better but still a little bit of a problem. I think its the way i have to move my leg when i hit the brakes.
rockyboy
Aug 4, 2024 10:35 AM
