Seafoam?
Seafoaming can be a 3 step process. First you nees to purchase Seafoam at an outo parts store. 1. Use 1/3 of the can in the vacuum line. Let the car sit 10 min. Then start it up and rev it. This should clean the carbon build up out of the engine. 2. Put 1/3 can in the crankcase. Drive it around for a bit, then go have the oil changed the same day. 3. Put 1/3 of the can in the gas tank.
before taking some old bad advice, go to the DIY section Seafoam and learn on page 6 the newly tesated and way better intake vac port to use.
1/3 can= ptttttttttttt
use a can in each place and the rewards are there for your investment!
Originally Posted by shizzytheking
do you think it's really better to use a whole can in each department and what else can seafoam be used for i read alot about people putting it in other places in there car
Yes, more Seafoam is better- slower getting it into the engine is better-
read any other thread or the DIY on seafoam for background- or search the net for their homepage. Its good for more things than can be listed on the can size!
Store your boat engine-use in lawnmower-deice gas-++++++++
The can directions must be read with a microscope to follow correctly, use azine methods and amounts. Well tested and proven- use the vac port at the Throttle Body to get it in the engine best
If the thought of using 20 bucks worth of stuff to make the car run better freaks you out:
I paid 57 U.S. dollars to fill up last night- the Seafoam helps me get evey mile out of that money that I can.
Its tune up in a can and much more.
If only I had gotten stock in them years ago, DOH!!!
acuratl26
04-23-2020 07:30 PM
EPS CL
06-02-2009 11:16 PM
manteuffel
03-12-2006 11:12 PM
