Scratch remover, Paint Detail, Cheap AND EASY!!!
im not advertising or anything, im just passin out information that helped me out ALOT.... www.paintscratch.com the website works with the actual paint code of your car... when u buy the paint they also prove primer, base, and clear coat!!!! check it!!
I've heard of this, touchup123 and others. Do you have any first-hand experience with pictures of how well this has worked? There have been mixed reviews on all of these products.
Duplicolor (and others) makes a kit with a small can of bondo and sandpaper to fill the holes, then you use their color code matched paint pen with a fine tip and bigger tip at other end to do 3 coats or so and a clear coat.
A little patience and good prep is all it takes
Will it be perfect, no
Good enough so you dont cringe when you look at the car? Yes!
Then get a 6-8 MM 3M type clear plastic bra and protect the front end
You can even put it on the trunk where the cats like to play
Also recommend paintless (and painless) dent removal for parking lot dings
You will not believe how well they come out and how happy your better half is!!
mugen_kid
11-13-2015 10:38 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
