Scratch remover, Paint Detail, Cheap AND EASY!!!
Old 05-03-2007, 05:05 PM
From a 2G to a 3G!
-MiG-'s Avatar
Thumbs up Scratch remover, Paint Detail, Cheap AND EASY!!!
im not advertising or anything, im just passin out information that helped me out ALOT.... www.paintscratch.com the website works with the actual paint code of your car... when u buy the paint they also prove primer, base, and clear coat!!!! check it!!
Old 05-03-2007, 08:49 PM
2002 TL-S NGP
Nothin' but Da Truth's Avatar
I've heard of this, touchup123 and others. Do you have any first-hand experience with pictures of how well this has worked? There have been mixed reviews on all of these products.
Old 05-03-2007, 10:11 PM
From a 2G to a 3G!
-MiG-'s Avatar
well, my TL is FILLED with scratches from the damn cats in my neighborhood.. its just like sad.. VERY noticible.. i just ordered the 1 once brush up paint today.. ill let u guys know!!
Old 07-01-2007, 05:42 PM
acura_fantacy's Avatar
any updates?
Old 07-01-2007, 06:07 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Duplicolor (and others) makes a kit with a small can of bondo and sandpaper to fill the holes, then you use their color code matched paint pen with a fine tip and bigger tip at other end to do 3 coats or so and a clear coat.
A little patience and good prep is all it takes
Will it be perfect, no
Good enough so you dont cringe when you look at the car? Yes!
Then get a 6-8 MM 3M type clear plastic bra and protect the front end
You can even put it on the trunk where the cats like to play
Also recommend paintless (and painless) dent removal for parking lot dings
You will not believe how well they come out and how happy your better half is!!
mugen_kid
11-13-2015 10:38 PM
Oakes
Wash & Wax
11-12-2015 09:34 PM
PortlandRL
09-14-2015 12:01 PM
Quick Reply: Scratch remover, Paint Detail, Cheap AND EASY!!!
