scraching....... Solutions??????
Old May 27, 2009 | 11:25 PM
Angel03TLs's Avatar
Question scraching....... Solutions??????
There is a scratching noise coming out of the front right tire area...The scratching sounds like the sounds very similar to the sound the break pads make when they are worn out....The bads that i had on when the noise started where not even a yr old and still no where near done but i still changed them...so with new pads and the rotors resurfaced i still get the scratching noise....some times i can hear it even when i'm not breaking maybe even when going over pot holes....i'm pretty certain it's not the back break pads because the noise is clearly coming from the from.......been having it for about a month and it's getting annoying..any help would be great
THANKS FELLAS
Old May 28, 2009 | 09:04 AM
FirePR2002's Avatar
bringin lead
could it be the dust shield behind the rotor is bent and touching something?
Old May 28, 2009 | 10:19 AM
01tl4tl's Avatar
noise travels in cars- dont believe your ears
Old May 28, 2009 | 11:53 AM
totaledTL's Avatar
Plastic inner wheel well splash shield?
Old May 28, 2009 | 01:36 PM
Angel03TLs's Avatar
i checked that as well and it's clear of that, it doesn't make any contact with the shield
Old May 28, 2009 | 01:48 PM
jp75's Avatar
you could have a sticky caliper
Old May 29, 2009 | 02:07 AM
Angel03TLs's Avatar
If this is the case can a rebuild of the caliper fix it or is it necessary to replace it(brand new)...also is it necessary two replace the left also or just the one with the problem?
Old May 29, 2009 | 04:56 AM
crazym0nkey's Avatar
Is the sound constantly there? Or does it come and go once in a while?
You say it sounds like brake pads wearing out, so it sounds like metal is scratching on metal?
If so, I have the same problem And my brakes are still good.
Old May 29, 2009 | 09:10 AM
jwskier187's Avatar
Had the same problem. Some people said check the brake dust shield and BAM it was all fixed. Id take another look.
Old May 29, 2009 | 10:17 AM
phee's Avatar
I got the Shifts
grab the brake dust shield and bend it back on all sides. shoudl go away
Old May 30, 2009 | 12:19 PM
formula1's Avatar
scratching
I have the same noise but only when turning. I dont know what it would sound like if one of the wheel bearings go out. Any ideas
cycdaniel
Dec 17, 2019 10:58 AM
The Machine
Sep 24, 2018 08:27 PM
LoneRonin
Sep 28, 2015 09:11 AM
AcuraKidd
Sep 25, 2015 11:18 PM
E92Vancouver
3G MDX (2014-2020)
Sep 21, 2015 02:32 PM
