View Poll Results: Not Under Warranty Maint!!! (You will have to pay for it)
Just Go to the Dealership
17.39%
Screw the Dealership
43.48%
Screw Scheduled Maint. I wait till I hear stuff falling off!
39.13%
Voters: 23. You may not vote on this poll
Scheduled Maint.
LOLZ McCain Sux
Scheduled Maint.
I am at 67,000 miles right now and I was thinking about when I am going to do my 75,000 mile Maint. Do you guys go to the Dealership or do you see what is suggested and have someone else do it?
Do the maintenance yourself. At 75K miles it's just normal tuneup items: oil change, ATF change, plugs, etc. Nothing too difficult.
First thing you should do is get a basic service manual. If you're not going to do more than tuneups, then a Chilton or Haynes manual will suffice. If you want to do more detailed work, then there's no substitute for a Helms manual.
In the end, not only will you learn how to work on your car, you'll save yourself thousands in the long run.
LOLZ McCain Sux
Az User
Received 2,573 Likes
get it done somewhere else or do it yourself, the only thing you might want the stealership to do is the tranny flush.
A safer way is doing a "triple flush" in which you just drain and refill the ATF 3+ times making sure to drive the car a bit between each change.
LOLZ McCain Sux
If you're talking about a machine tranny flush then I'd highly recommend against this process. The reason is that we can't drop the pans on our trannies, so when these flushing machines (ie. T-Tech) displace particles in the transmission, there's no way for us to get them out. As a result, there is a potential to cause harm to the transmission.
Originally Posted by JesusJuice
They put in a new Tranny on 3/21/05 how long do you think I should wait to flush it?
I suggest having the first fluid change no later than 15,000 miles after the transmission is installed to ensure wear-in before switching to a synthetic ATF for longer drains. If you plan on extending drains PAST 30,000 miles on ANY ATF, even Amsoil Universal ATF, a fluid analysis along with consultation with an expert such as Terry Dyson is highly recommended.
Michael
LOLZ McCain Sux
Originally Posted by 55M2G7L
i just bring it to my guy every 3k for the oil changes, he changes all the fluids and checks everything, id just do that if i were you unless you wanna get by the dealer
cahanging the fluid often isnt going to help our trannies either. i changed mine every oil change and that tranny lasted the shortest of them all
mugen_kid
11-13-2015 10:38 PM
