Rust on disc
Rust on disc
I just noticed areas on the disc (where the brake pads do not come in contact with the disc) have started rusting...Do you recommend any spray to remove this?
Thanks,
-tom
_______________
TL 2003 Nighthawk/Parchment
No mods yet.
Thanks,
-tom
_______________
No mods yet.
Re: Rust on disc
Thanks,
-tom
_______________
No mods yet.
Thanks,
-tom
_______________
No mods yet.
i do believe it may be just from the raim and so forth...as u drive and use your brakes the rust should come off... hope that helps
Your best bet is to sand the areas of the rotors that don't ever come into contact with your brake pads and paint them. While you are at it, you can paint the calipers to match as well. Should look nice, especially with rims.
I got this special paint from home depot that does not require that you sand off all the rust before painting. I just sanded off a bit of it, painted the rotors, let em' dry and they look beauuuutiful. I haven't seen a rusty rotor edge on my car in the last 8 months.
I painted my brake calipers with red caliper paint too.
Originally posted by johnnyb_s
Is there such a thing as caliper paint
I thought hi-temp paint would serve this purpose. What brand paint did you use?
I used a Plastikote spray paint that actually says "Brake Caliper Paint" right on the can. Found it at Pep Boys. I think it comes in black, red, blue, yellow, maybe a couple other colors. Under $5.
One can easily did multiple coats on all my four calipers with more to spare.
SidhuSaaB
May 30, 2020 12:40 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
lanechanger
Oct 13, 2015 10:56 AM
Need my sunglasses to look at that pic.
