Rough Idle during cold engine
Old Apr 11, 2003 | 12:24 AM
I have a 99 TL with about 90k miles on it....everytime I start it up and drive down the block...stopping at a light, I can feel the idle is kinda low,,,and theres a little shaking. Not sure if its an idle issue or a air flow issue. Does anyone experience this? Any recommendations. I've heard people saying it could be the throttle body...but I don't think that could be the problem??
Thanks.
Old Apr 11, 2003 | 12:57 PM
Tom Blasing's Avatar
is the Mighty Favog
This is only one possibillity but it could be the coolant temp sensor.
Old Apr 11, 2003 | 12:58 PM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
When it idles, what RPM is the needle saying?
Old Apr 11, 2003 | 01:00 PM
kkambbak9399's Avatar
http://www.acura-tl.com/forum/showth...threadid=54377
same problem i have. its starts to shake when i idling in Park or Neutral. They need to re-tighten the valves. its a wear and tear issue, not covered by warranty. $345. i haven't done it yet cos it doesn't shake that bad. and trying to raise the idle will only mask the problem.
Old Apr 11, 2003 | 02:37 PM
AK_MOBBER's Avatar
VOTE OUT THE BUSH REGIME
Mine idles rough at all times... Many times I can feel a noticable noise in my engine like a small thump that happens at random. I have replaced all spark plugs, run 91 gas, cleaned the intake and throttle body with carb/choke cleaner, have put in fuel injector cleaner also and octane boosters. Nothing has fixed the problem! (btw it still gets good gas mileage) strange???
A couple months ago the engine started to leak oil so I said Fock it and started putting in 87 octane gas and the cheapest 99 cent oil I could find. I honestly have no plans to fix it in the immediate future as I have other concerns besides a misfiring, oil leaking motor...
This may be my last acura...
Old Apr 11, 2003 | 05:06 PM
yup. i had a fuel injection cleaning, but the "thump" is still there. they need to re-tighten the valves.
Old Apr 11, 2003 | 10:55 PM
Well,,,the idle needle is in the normal range. Hmm coolant temp sensor? is that same as thermostat? I just changed my thermostat and that doesn't solve it. Do you think the extended warranty will cover this? thanks for all the messages..
Old Apr 11, 2003 | 10:58 PM
I'm sure its not a valve issue..valves you can tell by a knocking noise when you accelerate, and reduced power. I still get regular gas mileage and power.. weird..
Old Apr 11, 2003 | 11:15 PM
is the Mighty Favog
The coolant temp sensor and the thermostat aren't the same animal. The CTS is probably about the size of a spark plug and screwed into the side of the thermostat housing or somewhere close.
Old Apr 12, 2003 | 06:21 PM
Seotaji's Avatar
could also be the idle control valve, throttle position sensor, etc...
see if the computer is storing any codes.
Old Apr 13, 2003 | 01:31 AM
patrick's Avatar
$345? :wow: That's freaking expensive just to re-tighten the valves! Holy!
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
01CLOwner
Oct 9, 2015 01:07 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
NSolace
Sep 3, 2015 08:14 PM
