Rough Downshift into 2nd
Old Apr 3, 2007 | 09:39 PM
Colorado J's Avatar
Like the title says my car shifts hard into second from 3rd in MT mode. it kills my whole smoothness style. do i just need to put some tranny fluid in or do all tl s shift hard?
edit: yes even at lower rpms, like 3-4k in 3rd
Old Apr 3, 2007 | 10:15 PM
01tl4tl's Avatar
Need year model miles to help you best, original, 2nd or 3rd trans replacement?
To check trans fluid level- drive 15 minutes to normal operating temp.
Stop, Shut OFF engine.
Open hood, remove trans dipstick - the one on the RIGHT-driver side as you look at the engine
Remove - wipe clean- replace fully- remove and read- should be between the lines
If its leaking there is a problem- use Honda fluid only
My 01 has a new trans in it and I dont notice roughness, just the need to be on the brakes
as I downshift so max braking and the trans come on together
Old Apr 3, 2007 | 10:24 PM
Colorado J's Avatar
02 tl type s 43k miles 1st tranny. no leaking. ill do that tomorrow thanks man.
Old Apr 3, 2007 | 10:57 PM
01tl4tl's Avatar
register your car by VIN at www.acura.com ownership experience link
Make a free account and store your radio code plus get all the info on the
extended trans warranty and other info for your car
there is a list of approved sysmptoms for trans replacement there too- read up!
Old Apr 5, 2007 | 12:00 AM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
its normal it is a decent drop from 3rd. if you wait till the car slows down just a little bit more it wont be as rough.
Old Apr 5, 2007 | 09:40 AM
bkzjimmy's Avatar
NiGhT rIdEr
theres no need to downshift, it will do it on its own. even if your in SS.
Mike Pilipenko
Mar 26, 2024 09:21 PM
baelim
May 10, 2018 09:53 AM
RSpyder
Sep 30, 2015 12:46 AM
ceb
ILX
Sep 27, 2015 10:56 AM
