Right Turn Signal Problem
Old Aug 18, 2009 | 12:13 PM
harminder247's Avatar
:( Harminder Is Lost In
I have been having a problem with my car for the past few weeks. My right turn signal use to work when it wants but recently it just doesnt want to come on. If i turn on my emergency signal then all four lights function perfectly on the outside but inside only left arrow lights up. What could be the problem?
Old Aug 18, 2009 | 12:39 PM
01tl4tl's Avatar
all the bulbs are working? and the connectors clean and tight fit on bulbs
my buddy had a wiring harness drop down and get rubbed by the wheel on turns- went from not working right- to blows fuse on turns but the 4 ways work!
Once we found the wires and taped up the exposed part that was hitting metal rail and blamo` now its good
First he tried new signal switch and relay- fuses- then looked for the rsource of the problem~
Old Aug 18, 2009 | 12:41 PM
01tl4tl's Avatar
a little crc electrical contact cleaner shot inside the signal contacts in steering wheel might help
Old Aug 18, 2009 | 01:36 PM
Yea I don't get it, all the lghts work but just doesn't work when I try to use the right signal. Probably is a wire that got cut or something I guess. I'm going to pull off the bumper and double check wiring. Thanks for the input
Old Aug 18, 2009 | 01:37 PM
do I need to open up the cover?
Old Aug 20, 2009 | 03:08 AM
turns out it was the bulb in the cluster!
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
