Restoration of the Shift Plate
Old Jul 8, 2007 | 05:10 PM
AcuraKidd's Avatar
The Talk of New York
Question Restoration of the Shift Plate
So I'm basically tired of looking at my scratched up shift plate and wanted to make it look a little more cleaner and newer.
I've heard that its possible to sand it down, and do some other stuff to it to make it look like new again.
Could somebody please point me in the right direction on how to sand it, what to use, etc..., I basically need step by step instructions.
Old Jul 8, 2007 | 05:53 PM
6MTUA5's Avatar
No He Can't
Just sand it down a little to rough it up and paint it whatever color you want it
Old Jul 8, 2007 | 06:02 PM
adamlee05's Avatar
Thread Police Chief
if its a 99 model you can make it look chrome by sandind down the silver paint a little. 99-03 you cant do that.
As for repainting it, just rough it up with some sandpaper, primer, and paint.
goodluck
Old Jul 8, 2007 | 09:34 PM
FL3.2TL's Avatar
Just chillen..
I would do this to restore the shift plate but it depends on the scratches ( deepness ):
1) Wet sand using 1000 grit ( Get it smooth )
2) Wet sand using 1500 grit ( Get it smoother )
3) Prime
4) Wet sand using 1500 grit
5) Prime
6) Wet sand using 2000 grit
7) Prime
8) Paint
Of course they are shorter ways, but that would be my way. I wouldnt recommend using anything under 1000 grit
Example of shorter way: Wet Sand with 1000, then 1500, then 2000, prime, wet sand 2000, paint
Take it easy
Old Jul 8, 2007 | 09:37 PM
csmeance's Avatar
goodluck
the first gen guys use paint thinner/laqure and they get the chrome finish without sanding.
Old Jul 8, 2007 | 10:15 PM
vzuptnguyen's Avatar
B A N N E D
nice steps fl, but this is simply a shift gate and not something greatly noticeable.
godzilla, just use any sandpaper greater than...say 300-400, then use like a 800. then primer and paint.
i have built up some skills on bodywork working on my friends car. i usually prep the car a lot before painting, but this is a very small task, and you cant mess it up.
Old Jul 8, 2007 | 10:23 PM
AZN.M3NACE's Avatar
USDM -> JDM
if u just sand it down, you dont need to paint it either.. looks great without it being repainted.. i sanded mine down and it looks new even without the paint
Old Jul 8, 2007 | 10:35 PM
6MTUA5's Avatar
No He Can't
Actually just use paint stripper and spray it on. Let it sit and it starts dissolving the paint then you just wipe away the old paint and rinse it off with some water.
But, all this doesn't matter b/c the OP has a 2002
Old Jul 9, 2007 | 05:27 PM
TL.00.3.2's Avatar
well i made a diy for this. click the link.
https://acurazine.com/forums/technology-16/eh-canucks-apple-itunes-kanada-open-162482/
Old Jul 9, 2007 | 08:57 PM
VoLLy's Avatar
Meridian
This is what I did with mine:
Old Jul 14, 2007 | 08:52 PM
AcuraKidd's Avatar
VoLLy_1llusioNz, that looks very nice, anything special you did to it to make it look like that?
Old Jul 16, 2007 | 01:12 AM
AZN.M3NACE's Avatar
USDM -> JDM
what i did was just sanded it down.. no paint or anything and it looks like this below:
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Hines57
Sep 24, 2015 01:58 PM
