"resetting" your ecu?
Old Apr 7, 2008 | 11:51 PM
bigeshorte45's Avatar
so i was reading a thread a few nights ago (cant remember which one) and somebody had posted about how after every MOD they do they unplug the battery, let the car sit for 10 minutes, restart the car, let it sit without touching the gas untill the fan starts, then turn the car off and it "resets" your ecu? am i wrong? they said it helps the car get used to the differences or something (sorry im not realllllll smart about cars) but they also said some people do this every year when the season changes due to the differences in gas and such..... anybody have anything to say to this?
Old Apr 8, 2008 | 12:24 AM
MurkyRiversTL's Avatar
COTM Coordinator
You can do that but its not necessary. Instead of going through that 20 step process, you can just as easily pull the "CLOCK BACKUP" fuse on the passenger side fuse panel to reset the ecu. Or you can disconnect the negative terminal on the battery.
There is no need for all that other foolishness.
Old Apr 8, 2008 | 03:03 AM
01tl4tl's Avatar
Only after a mod that effects the engine intake or exhaust or rev abilty
Then do a reset so it relearns the car
fuse #12 clock backup fuse is the real power source for the ECU- Engine Control Unit
Old Apr 8, 2008 | 07:06 AM
fsttyms1's Avatar
Actually if i remember correctly the 02-03 should have a ECU relearn by doing something like stated
Old Apr 8, 2008 | 10:28 AM
01tl4tl's Avatar
Read the section of the owner manual on_ preparing for Smog Test
that should provide some more insite as to driving a special way for 30 minutes or such- the 01 has that instruction
Old Apr 8, 2008 | 10:31 AM
hmmmmmmmmmmm well i just removed the "mid-muffler" underneath my car... think i should do this?
Old Apr 8, 2008 | 12:10 PM
01tl4tl's Avatar
It wont hurt to do it- happens when you clean the battery terrminals~
Old Apr 8, 2008 | 12:18 PM
fsttyms1's Avatar
No need to reset it for removing the mid muffler.
Old Apr 8, 2008 | 01:46 PM
01tl4tl's Avatar
cmon kris- I am on a springtime campaign to clean battery post and wires after a wet winter for most ziners~
Good ground and hot leads make for better running car, and of course- Seafoam!
TypeS860
Jan 10, 2026 11:11 AM
cycdaniel
Dec 17, 2019 10:58 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
