resetting Maintence Required light
Old 07-01-2003, 01:44 PM
Got a oil change and they didn't reset the light. Does anybody know how??
Old 07-01-2003, 01:47 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
read the owners manual, its in there!
press and hold the trip and reset buttons and then turn the key to the run position and hold for ten seconds
Old 07-01-2003, 01:59 PM
Old 07-01-2003, 07:15 PM
SilverUA5's Avatar
you can turn the key first and then hold the 2 button, if you do it right, you can adjust your outside temp guage.
Old 07-02-2003, 09:32 PM
is the Mighty Favog
Tom Blasing's Avatar
I played around with it and it finally worked.
Turn the ignition key to position 3 (RUN but not started), Then push in the trip odometer button and then the Select button. Hold both buttons in till you hear a segmented 'beep' (about 5 seconds) and see the temp guage displaying "3, 2, 1, 0, -1, -2, -3". This is how far lower or higher the correct temp should be from the current temp the car displays. When it gets to your number just let the buttons go.
VIOLA!!
Now if I could just convince the outside weather to be 75 when it's really 25..........
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
95legend6speed
09-21-2015 06:40 PM
PortlandRL
09-14-2015 12:01 PM
vbgregg
09-11-2015 05:38 PM
ptbarnett
3G RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: resetting Maintence Required light
