Resetting the computer
Old May 25, 2001 | 03:32 PM
rockinTLS's Avatar
Question Resetting the computer
Is there a fuse you can pull to reset the engine ECU or do you have to disconnect the battery?
My old Legend has a fuse called "Alt Sense" which, when removed for 30-40 seconds, will reset the ECU.
Old May 26, 2001 | 06:16 PM
Road Rage's Avatar
Not a Blowhole
Post
Pull the fuse or the relay - check the owner's manual for the location.
Question is - why? The ECM constantly monitors and optimizes your fuel flow and timing based on readings from the sensors.
Rage On!
2002 TL-S w. Comptech header/exhaust, springs
SSR Integral A2's
17x7 45mm offset
Pirelli P7000 (Summer) 215-50/17
Jinkazetsukai
Nov 21, 2015 05:28 PM
brboy
Oct 5, 2015 11:34 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
AcuraKidd
Sep 25, 2015 11:18 PM
