replacing fog light bulb
Originally Posted by Sniper 55
What color are you looking for from the Bulb ??
That i am not sure of, i just want something brighter than OEM.
Agean Blue Bishes
1 Post
your not gonna notice a huge diff with diff bulbs in the fogs. personally i didn't think the figs did much for light output, then i put hids in then they put out more light than my headlights
Agean Blue Bishes
1 Post
yes. but don't expect much just a color change. its not like with new bulbs your gonna see any better. if you want something that matches the hid a little better just get silverstars.
just don't up the wattage. fogs are only rated at that wattage cause they can't take any more heat from a higher wattage bulb (in most cases, i know many will prove me wrong)
wally = walmart
any colored light is gonna burn out faster no matter what, so just beware of that
13.2@ 107 on Street tires
Originally Posted by merkin110
weres the best place to purchase silverstars?
'02blAcuRAT!! soooCool!!
Originally Posted by type-s09
I found the silverstars at autozone fore 32 bucs which is cheaper than walmart(38). I love the new look considering it matches the color of the stock HIDs. I also replaced the factory high beam which also helped the look and brightness.
Originally Posted by MY2002TLS
So what is the stock wattage for the fogs?
I just got 6500k, will I see any color difference to the stock ones?
You got a HID kit i take it? thats about the only way your going to get a true 6500k. Yes you will see a difference, the stock headlights are only 4300 and halogens are less than the oem hid
I said screw it and i went with OEM. It was only 12 bucks
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
