Replacing comptech foam filter with K&N?
Old May 17, 2004 | 03:42 PM
Mongolian's Avatar
if i change the foam filter that came with icebox to K&N filter, will there be an increase in sound?
Old May 17, 2004 | 03:52 PM
jpadilla's Avatar
Which K&N filter would u replace it with? I didn't know K&N had one for the comptech icebox.
Old May 17, 2004 | 04:48 PM
ou sig's Avatar
Boomer SOONER
not going to happen, you buy the Comptech Icebox and are stuck with the Comptech foam filter.
Old May 17, 2004 | 05:07 PM
dcostatl's Avatar
replacement k&n filter
Hey Guys I Replaced My Comptech Ice Box Filter With A K&n Filter Part # Ru-2590 .note: The Inlet On The K&n Had To Be Stretched About Another 8th Of An Inch .. I Just Used A Heat Gun To Expand Inlet ...the Comptech I Found Had To Be Cleaned More Often.. Hope This Helps...danny..
Old May 17, 2004 | 05:10 PM
dj5's Avatar
dj5
Replaced my foam filter in the icebox with the K&N as well. I would say there might be a slight increase in sound but not much.
Old May 17, 2004 | 07:25 PM
andyc039's Avatar
would the k&n filter replaced over the stock change the noisE?
Old May 17, 2004 | 10:37 PM
jpadilla's Avatar
what part number did u use?
Old May 17, 2004 | 11:03 PM
nortondlcl's Avatar
Old May 17, 2004 | 11:05 PM
nortondlcl's Avatar
any performance increase between the both filters?
Old May 18, 2004 | 12:19 AM
ou sig's Avatar
Boomer SOONER
damn I spoke too soon...
Old May 18, 2004 | 02:50 AM
azn g ryde's Avatar
Not really
There is alot of people on the CL forum that had the icebox with the foam cone and changed it to a K&N Filter. I did it over the weekend. There might be a tad more noise. I am very sensative to my car like any little thing I pick up so I was able to pick up a little more noise but not much. Performance. No dyno or aything. Purely based on feeling, I say a little more smoother with the K&N filter. Could be psychological but my girl drove my car and I didnt tell her about the filter and she said my car was running smoother then I told her. Hope that helps. The part number is 2950.
Ad for the fitment. Many people over on the other gorum took off the ring around it. I think its ok becasue the way the filter is positioned. IT is jsut laying there but I put on the ring anyways jsut for security purposes. first I had trouble puttin on the filter becasue the ring restrict the rubber cone to stretch and it does need to stretch a bit to fit. But i just open the clamp as wide as possilbe then slide it towardsthe piping. After I got the filter in then slide the clamp pver the filter then tighten. I suggest taking the elbow off the icebox. Makes thigs easier. after you get the filter back on the slide the elbow back in
Old May 18, 2004 | 09:17 AM
dj5's Avatar
dj5
Check out this thread for more discussion on the K&N filter in the icebox.
http://www.acura-cl.com/forums/showt...t=K%26N+icebox
nanos
Nov 12, 2015 08:41 PM
Skirmich
Sep 15, 2015 06:41 PM
k6biv
Sep 10, 2015 06:37 PM
Aleax
Sep 9, 2015 08:04 PM
