Replacement air filter
Old Jul 8, 2001 | 04:59 PM
Question Replacement air filter
Hi I would like to know what are the differences in HP and Torque gains between the CAI, Short Ram and just a replacement filter like K&N or Comptech filter.
Thanks.
Old Jul 9, 2001 | 12:38 PM
R Man's Avatar
From what I've read on this forum, the AEM CAI will add 2 or 3 hp. K&N advertises that their filters add 2 or 3 hp also. I'm guessing that the same goes for the Comptech filter as well.
I chose to go with the simple drop-in filter rather than the CAI. I didn't want the added expense or the shrill scream that I've heard the CAI has. Just make sure you clean and oil the filter every 7500 miles or so.
Old Jul 9, 2001 | 07:04 PM
Bitium's Avatar
Retired MOD
Here is my opinion:
http://www.acura-tl.com/forum/showth...threadid=16041
Old Jul 9, 2001 | 07:18 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
Originally posted by Bitium
Here is my opinion:
If you don't take out the resinator, how is the sound effected? Less deep sound? Really thinking about getting the Hi-Flow Drop in filter..
Old Jul 9, 2001 | 08:11 PM
Bitium's Avatar
Retired MOD
Well, what affects the sound the most is the pipe and how much air goes in. For example, when I had the short ram, I took out the filter and the sound was the same with or without the filter.
I truly don't know what the bottom box does, but I didn't notice any change in sound when it was removed compare to when it was there. The reason I took it off, was to induce cold air.
The sound when replacing just the OEM filter with a high flow filter, comes from letting more air in the upper pipe. So removing the bottom box(resornator) won't affect the sound.
Old Jul 9, 2001 | 08:25 PM
Edub-TL's Avatar
Ahhh.. so removing the resinator effectively gives you a quieter CAI.. I'll have to remember that..
Old Jul 9, 2001 | 08:31 PM
ALFAV6's Avatar
Super Troll
Question
does the drop in fiters also work for the 2002 TLS?????? cause AutoCarsParts.com shows its only for the 99-01...... Thanks guys
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
Aleax
Sep 9, 2015 08:04 PM
sputik
Sep 7, 2015 01:40 PM
bymotion
Aug 31, 2015 05:00 PM
