removing turbo timer
Old Feb 10, 2008 | 12:32 PM
takahashi's Avatar
B A N N E D
hey if i want to remove my turbo timer, can i just remove the unit from all the wires? or should i disconnect it from the sources its connected to i.e., fuse, grounds...
wouldnt removing the unit alone sufficient enough to disable the unit?
its a gReddy gtt3.
thanks guys.
Old Feb 10, 2008 | 05:46 PM
01tl4tl's Avatar
Does the unit hook up to its own oil filter system that runs after the engine is off?-
or just keeps the engine running on a timer for a few minutes?
Always better to remove wires than leave potential hot leads where they can Ground and cause you head-scrathing problems later!
Old Feb 10, 2008 | 08:49 PM
takahashi's Avatar
B A N N E D
no i did not connect it there.
and yes, i know what you mean about the wires.
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
mvidal6
ILX
Nov 14, 2015 07:43 AM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
